SV07 Plus Z-Tilt problems and having to retry a print 2-4 times before it prints
When doing the z-tilt before a print. I’m having problems with getting the “Retries aborting: Probed points range is increasing.” It does this 2-3 times before it finally completes and continues. Here is a sample of the output from starting a print. Bed is level, z-offset set correctly, mesh is there. OrcaSlicer! Any ideas? This is a new machine to me, and my first foray into Klipper. I previously had an Ender 3 Pro that I had just outgrown and gave to the kids. I had to do only one restart this time (it’s normally 3 times):
5:23 PMRetries: 1/50 Probed points range: 0.001250 tolerance: 0.002500
5:23 PMMaking the following Z adjustments:stepper_z = 0.010695stepper_z1 = 0.009456
5:23 PMprobe at 260.000,170.000 is z=1.757934
5:23 PMProbe samples exceed tolerance. Retrying…
5:23 PMprobe at 260.000,170.000 is z=1.755434
5:23 PMprobe at 260.000,170.000 is z=1.742934
5:23 PMprobe at -8.000,170.000 is z=1.760434
5:23 PMprobe at -8.000,170.000 is z=1.757934
5:23 PMprobe at -8.000,170.000 is z=1.752934
5:23 PMprobe at -8.000,170.000 is z=1.735434
5:23 PMRetries: 0/50 Probed points range: 0.018750 tolerance: 0.002500
5:23 PMMaking the following Z adjustments:stepper_z = -0.010434stepper_z1 = 0.008307
5:23 PMprobe at 260.000,170.000 is z=1.760607
5:23 PMprobe at 260.000,170.000 is z=1.758107
5:23 PMprobe at 260.000,170.000 is z=1.748107
5:23 PMprobe at -8.000,170.000 is z=1.745607
5:23 PMprobe at -8.000,170.000 is z=1.738107
5:23 PMprobe at -8.000,170.000 is z=1.733107
5:23 PMprobe at -8.000,170.000 is z=1.708107
5:23 PMZ-Tilt…
5:23 PMZ-Tilt: Waiting for min/max bed print temperature of 45.6°C / 57.8°C…
5:23 PMBed print temperature fits saved mesh. Loading mesh ‘default’.
5:23 PMOpportunity to clean the nozzle / bed…
5:23 PMPreheating nozzle to 143.5°C, to prevent ouzing.
5:23 PMOn: Use Saved Mesh. 55.0°C was the last bed temperature.
5:23 PMOn: Prime Spiral Left
5:23 PMOn: Prime Line (front)
5:23 PMOn: Z-Tilt
5:23 PM1.749: Z-Offset
5:23 PMExternal Part Fan: OFF
5:23 PMTarget Temperatures: Bed:55.0°C, Nozzle:205.0°C
5:23 PMJust another best print of my life. Version 2.0
5:23 PM
5:23 PMFile selected
5:23 PMFile opened:cane_holder_clamp_latch_texture_v1.gcode Size:9260865
5:23 PMRetries aborting: Probed points range is increasing.
5:23 PMRetries: 4/50 Probed points range: 0.028750 tolerance: 0.002500
5:23 PMMaking the following Z adjustments:stepper_z = 0.028133stepper_z1 = -0.000607
5:23 PMprobe at 260.000,170.000 is z=1.745847
5:23 PMprobe at 260.000,170.000 is z=1.740847
5:23 PMprobe at -8.000,170.000 is z=1.773347
5:23 PMprobe at -8.000,170.000 is z=1.770847
5:23 PMprobe at -8.000,170.000 is z=1.768347
5:23 PMprobe at -8.000,170.000 is z=1.743347
5:23 PMRetries: 3/50 Probed points range: 0.025000 tolerance: 0.002500
5:23 PMMaking the following Z adjustments:stepper_z = 0.026653stepper_z1 = 0.001653
5:23 PMprobe at 260.000,170.000 is z=1.749958
5:23 PMprobe at 260.000,170.000 is z=1.742458
5:23 PMprobe at -8.000,170.000 is z=1.772458
5:23 PMprobe at -8.000,170.000 is z=1.769958
5:23 PMprobe at -8.000,170.000 is z=1.764958
5:22 PMprobe at -8.000,170.000 is z=1.752458
5:22 PMRetries: 2/50 Probed points range: 0.015000 tolerance: 0.002500
5:22 PMMaking the following Z adjustments:stepper_z = 0.030052stepper_z1 = 0.015042
5:22 PMprobe at 260.000,170.000 is z=1.762460
5:22 PMProbe samples exceed tolerance. Retrying…
5:22 PMprobe at 260.000,170.000 is z=1.774960
5:22 PMprobe at 260.000,170.000 is z=1.759960
5:22 PMprobe at 260.000,170.000 is z=1.757460
5:22 PMprobe at 260.000,170.000 is z=1.742460
5:22 PMprobe at -8.000,170.000 is z=1.777460
5:22 PMprobe at -8.000,170.000 is z=1.772460
5:22 PMprobe at -8.000,170.000 is z=1.754960
5:22 PMRetries: 1/50 Probed points range: 0.023750 tolerance: 0.002500
5:22 PMMaking the following Z adjustments:stepper_z = 0.033797stepper_z1 = 0.010040
5:22 PMprobe at 260.000,170.000 is z=1.761139
5:22 PMprobe at 260.000,170.000 is z=1.758639
5:22 PMprobe at 260.000,170.000 is z=1.748639
5:22 PMprobe at -8.000,170.000 is z=1.786139
5:22 PMprobe at -8.000,170.000 is z=1.783639
5:22 PMprobe at -8.000,170.000 is z=1.776139
5:22 PMprobe at -8.000,170.000 is z=1.751139
5:22 PMRetries: 0/50 Probed points range: 0.062500 tolerance: 0.002500
5:22 PMMaking the following Z adjustments:stepper_z = -0.076139stepper_z1 = -0.013649
5:22 PMprobe at 260.000,170.000 is z=1.739000
5:22 PMprobe at 260.000,170.000 is z=1.734000
5:22 PMprobe at 260.000,170.000 is z=1.729000
5:22 PMprobe at 260.000,170.000 is z=1.716500
5:22 PMprobe at -8.000,170.000 is z=1.676500
5:22 PMprobe at -8.000,170.000 is z=1.671500
5:22 PMprobe at -8.000,170.000 is z=1.664000
5:22 PM
Did you have any luck getting this fixed? I am still seeing the same issue. I can get one thing to print, then starting the second, it takes several hours to get the bed leveled again. What am I doing wrong?
I had similar experiences with mine and ultimately it came down to loose wheels on the z axis and loose Allen head screws on the bracket attaching the anti backlash nuts.
Once I got everything tightened up, my z axis troubles pretty much disappeared.
Hope this helps.
Greg
How much should I tighten those screws?
Thanks, so these screws of the backlash nuts, do they have to be tightend as much as possible? On Sovol Homepage photos they seem to have little space between bolt head and base bracket plate of the gantry?
Maybe their picture is not correct?
For anyone experiencing the same issue and your search for a solution brings you here, the answer is “make the bolts tight”. Some thread lock liquid would be a good idea, too!
So you mean to properly tighten these two bolts and it works then?
Best regards
Yes, that’s all I had to do. All 4 screws were loose and once I tightened them everything was good again.
One more issue, maybe someone can help. Is it correct that the springs get more and more compressed without any action from my side? Screws left and right next to the nuts are tightened properly.
Is this normal or is there anything i could do to uncompress springs again if this maybe helps to make z tilt more accurate again?
Best regards and many thanks
