Hi everyone
So I recently bought the 3d printer model SV07 Plus, and after assembling it was ready to fire it up.
Prepared it and started making the preparations, I made a print test (the popular small ship) and it was fine. I wanted to calibrate it again to make the next print, only for it to keep changing the numbers on the different bed corners, even when I hadnt even touched them! Not only that but when we do infact try and do the z-tilt, on the left side it, pushes the bed down IMMENSELY. You can even hear it grinding inside the base. This error also comes: “Retrys aborting: probed points range is increasing” Z calibrate works.
Im all out of ideas and im really tired of spending hours of trying to calibrate a printer that just doesnt stick. If anyone has had any similar problems or just tipps I would really appreciate it.
