I have had the SV06 since Feb and it has worked perfectly until recently. The first layer goes down fine on one side of the bed, then the filament either starts to curl behind the nozzle or doesn’t stick as it goes along the rest of the bed.
I have tried multiple Z alignments, adjust Z offset and bed leveling.
I have updated firmware and made sure the bed mesh is being loaded.
I did notice during the first layer, the left z motor is clearly moving to adjust according to the mesh. And the right Z motor does not move as noticeably as the left motor. The Z motors look to move fine during regular Z axis moves.
I lubricated the Z rods, lead screws, made sure the Z couplers were tight.
I even swapped the Z motors to opposite sides to determine if it was the motor, but nothing changed.
I have been stumped on this issue for the past week and wondering if I am overlooking something. I have not seen anyone else with the same issue.
If anyone has any suggestions, I would appreciate it.
Thanks in advance.
