All setup done per instructions.
Printer was fine and then not.
After i start a print the first line that prints down the left side of the bed (not sure what its called) starts too high ( starts extruding with z axis too high) and is not in the correct offset -1.60 for about 1 cm and then lowers to the correct height. Then its returns on that same line (2nd layer) and raises about the same location and extudes a bit more but pulls the filament a little to the center of the bed (end looks like a J) and is not adhered to the bed. Any idea why this is happening? Other than that it prints fine once the actual print starts.
