I’ve had this issue a few days ago. It happened when I started a print job without clearing the bed. When I try to home the Z axis it simply jams in the bed and I have to emergency stop it. It sounds very similar to the issue here:
I believe I set the ZOffset to WAY higher and WAY lower but the behavior is the same. I believe that it was at 2.5mm before. I just tried setting it back to factory but same thing.
When I try to “Home Z Axis” it says that the Z Axis is over 500mm, when it is just above the bed, then it crashes into it.
I checked the connections that I screen-shotted and it all appeared to be connected. I am not sure how to remove the extruder outer case so I couldn’t check inside of that (not sure if that is what you were getting at)
Also, the “blue cylinder” thing is also seemingly jammed deep in the extruder. IDK if that is an issue but I thought I would point that out.
If you mean the thing that I have circled in red here, that is the vertical distance sensor. It tells the distance between itself and the printbed, and is adjusted so that the nozzle is in the right position and doesn’t crash into the printbed.
And yes, If that has changed position ever so slightly, you will have problems like you describe.
I have the same issue with my SV 08. Someone said you have to change something in Klipper but I never read what . It doesn’t happen every time it usually happens after a print. And then try to print another plate very soon after that. I heard it related to heat soak if my Solvol Eddie. But I sure don’t know how to fix it.
Bill, if it only starts after a print and another plate soon after, I’d treat it as probe/heat drift until ruled out: let it cool, home Z, then repeat after a warm soak and compare. Also check the probe/vertical-distance sensor mount and connector haven’t shifted—on the SV07 that sensor being slightly off causes exactly the nozzle-into-bed behavior. The Z over 500 mm reading sounds more like the probe/endstop state than Z-offset, so don’t keep re-running homing into the bed; fix the trigger first.
