I ordered an SV08 on April 18, 2020 and then received it at the beginning of July 2024.
From the beginning I had problems with the Z-Offset, which destroyed a printing plate and a nozzle, so I contacted the support.
Support then replaced this for me.
(25.7.2024).
Z-Offset had to be adjusted +/- 0.4 each time, but I just worked with it.
In December I contacted support again because the printer continued to have Z-Offset problems and regularly canceled printing or shifted the layers.
(31.12.2024)
The only reply was: “Hello,
It is recommended that you re-adjust the level of the hot bed,
print and adjust the offset value of the horizontal test model, and save it.”
When asked, the following answers came “Hello,
We recommend that you follow the steps below to troubleshoot and provide us with feedback.
- it is not recommended to print a model of too large size on the hot bed. If the hot bed is not adjusted properly, the model will be damaged and waste materials. It is recommended to print a smaller model and print it several times.
- please refer to the flashing video to refresh the SV08 firmware, reprint the model, and observe the effect of the model.”
(three mails, 31.12, 2.1, 8.1.2025)
After 11 more emails, a tracking number with the first spare parts arrived on 5.3:
A hotend and a filament sensor
Nevertheless, the errors “mcu ‘extra mcu’ shutdown” and error nr 3 remain.
then, on 12.3 i recived a mail to do a firmwareupdate - i dit it, nothing changed.
on 14.3 they sent me these parts:
Hotend Adapter Kit
flat ribbon cable
Unfortunately that didn’t help either, still the same problems.
Answer:
“Dear Customer,
I’m really sorry to hear that you’re still facing the issue, and I understand how frustrating this can be. Let’s go through a couple of steps to resolve this:
Check the Adapter Board and Cables:
The firmware on the adapter board might be different. Have you already tried replacing the adapter board and data cables?
If Replacing the Adapter Board and Cables Doesn’t Help:
If changing the adapter and cables did not resolve the “time too close” error, please follow these steps:
Access the Mainsail interface on your printer.
Take a screenshot of the error message in Mainsail and note the exact time the error occurs.
Download the log file from the Mainsail interface and send it to us for further analysis.”
Yes, i did everything.
On April 2, I received an e-mail that I should reflash the firmware on the mainboard and the print head with the STLINK emulator, and I also received new circuit boards for the print head.
After flashing, the prints stop again, Eroor code 14, and “mcu ‘mcu’ shutdown”
Answer from Sovol:
- check the printer connection: First, make sure the printer connection is normal. Check whether the printer’s power cord, data cable, and extruder adapter cable are plugged in tightly.
- restart the computer: If the above steps do not solve the problem, try restarting the computer.
- if it does not work, you need to refer to the following tutorial to refresh the firmware of the adapter board and motherboard, and give us feedback.
How to burn firmware to the motherboard/adapter board How to burn firmware to the motherboard/adapter board | Sovol 3D Printer Wiki - restart the printer and connect to the printer wifi, select show IP on the knob screen, enter the ip address displayed on the knob screen from the computer, and enter Mainsail;
How to connect to WIFI: https://youtu.be/ODud4t_qWdQ?si=gkbsnvu40A03WMtO - after successfully connecting to wifi, please remember your machine ip address. We will need you to provide a screenshot of the error message on the Mainsail interface so that we can better troubleshoot the machine for you;
All done, even if I don’t understand what my PC has to do with the problems with the printer.
Now my camera no longer works either.
I really don’t know what to do anymore.
