Got the machine and enclosure all assembled, and on the first boot of the SV08 Max I get the following error:
mcu ‘mcu’: Unable to connect
Once the underlying issue is corrected, use the
“FIRMWARE_RESTART” command to reset the firmware, reload the
config, and restart the host software.
Error configuring printer
I AM able to view the machine via mainsail connected via wifi.
I did send a support ticket with my order number, but have yet to hear back.
Any Ideas on where to start?
Exact error…straight from the printer screen and mainsail.
So far, without success I have reset mainsail and rebooted from the mainsail screen, but am still getting this error
The main mcu shares the same circuit board as the SBC running klipper so not much chance of a loose wire. Are you comfortable with the Linux terminal VIA SSH?
Skip ahead to the section starting with the command /lsusb
Don’t flash katapult and/or firmware onto the MCUs without consulting Sovol. That guide is for generic DIY components.
You might try unplugging the buffer and the toolhead (one at a time). If CANhi and CANlow are shorted it could take down the whole bus. With the printer powered off measure the resistance from CANhi to CANlow, with the wires connected. It should be 60 Ohms
sovol@SPI-XI:~$ lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 32e6:9221 USB 2.0 Camera USB 2.0 Camera
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Okay then the CAN is connecting to the buffer_mcu.
As best as I can tell the next step would be to reflash the (main)mcu firmware.
There are no instructions from Sovol on how that is done for the Max (or the Zero which also runs CAN). There is a Python module in the OS image from Sovol. I can walk you through executing it in the SSH terminal window but I have NO IDEA if it would work and warn there is a 10% chance it makes the situation worse.
home/sovol/printer_data/build/mcu_update_fw.sh
#!/bin/bash
echo "Start mcu_update_fw.sh now!!!"
# Check if python3-serial is installed
if dpkg -l | grep -q "python3-serial"; then
echo "python3-serial installed."
else
sudo apt-get install python3-serial -y
fi
# Check if klipper.bin exists
if [ -f /home/sovol/printer_data/build/mcu_klipper.bin ]; then
# Check if flash_can.py exist
if [ -f /home/sovol/printer_data/build/flash_can.py ]; then
echo "Found flash_can.py"
else
echo "No flash_can.py found in /home/sovol/printer_data/build.Exiting..."
exit 1
fi
# get into mcu bootloader
echo "Get into bootloader ..."
python3 ~/printer_data/build/flash_can.py -f ~/printer_data/build/mcu_klipper.bin -u 0d1445047cdd &
check_pid=$!
sleep 5
kill $check_pid
#get bootloader id
bootloder_id=$(ls /dev/serial/by-id/* | grep "usb-katapult_stm32h750xx")
# Check if bootloader id is detected
if [ -z "$bootloder_id" ]; then
echo "Failed to detect bootloader id! Exiting..."
exit 1
fi
# Flash MCU firmware
python3 ~/printer_data/build/flash_can.py -f ~/printer_data/build/mcu_klipper.bin -d "$bootloder_id"
else
echo "No mcu_klipper.bin found in /home/sovol/build. Exiting..."
fi
It looks pretty straightforward. But I know just enough Python to be dangerous.
I have all the tools to do this…even an extra EMMC card. Bought it to upgrade my SV08 to mainline klipper, which I haven’t done yet. Would this be something to consider?
There are 2 different “systems” on your mainboard. Despite the filesystem warning the Linux install seems to be working “okay”. Flashing the EMMC will reset the Linux install but will do nothing for the MCU side. The MCU runs Klipper from internal memory (that you just tried to update).
I’m curious to see if flashing the EMMC clears the filesystem warning BUT I’m extremely doubtful it’ll solve your CAN issue.
