mighty1
November 25, 2023, 9:08am
1
Hi guys,
I’m writing this because i can’t deal anymore with this printer. I’ve had some troubles with the update, the klipperscreen was dead, ordered the mks adapter for the emmc, did everything i could, read everything i could, but at some point, i’ll lose focus and interest.
The touchscreen is working now, but i get this mcu error. Tried everything that i could, but i’m willing to try more, if someone has some advices.
It’s my first printer and unfortunately, not the greatest experience.
Is there anyone here that had this situation?
moonraker.log.txt (42.1 KB)
klippy.log.txt (105.0 KB)
I’ve attached the logs, hope someone will give me an input on this.
Best,
Silviu
knw257
November 26, 2023, 4:30am
2
The error in question
serialhdl.error: mcu 'mcu': Serial connection closed
mcu 'mcu': Timeout on connect
Implies that the USB cable to the printer mainboard isn’t fully connected. This could be as simple as a loose cable, or as complex as a bad driver on the screen. My two suggestions are to verify the USB connection, and to completely reimage the emmc chip with the image available from Sovol’s downloads page.
It might help if you can SSH into the printer, and run the command
lsusb -v
and post the output here. Also, grab the output for
ls /dev/serial/by-id
mighty1
November 26, 2023, 6:05am
3
knw257:
lsusb -v
_ _
_ __ ___ | | _____ _ __ ()
| ’ ` _ | |/ / | ’ | |
| | | | | | <_ \ |) | |
| | || | ||__/ . /| |
|_|
Welcome to Armbian 22.05.0-trunk with bleeding edge Linux 5.16.20-rockchip64
No end-user support: built from trunk
System load: 22% Up time: 2 min
Memory usage: 47% of 976M IP: 169.254.231.217 192.168.1.208
CPU temp: 41°C Usage of /: 72% of 6.8G
RX today: Error: eth0: Invalid database daily date order: 1550141664 (0)
< 1679105495 (1) Error: eth0: Invalid database daily date order: 1550140736
(0) < 1679105495 (1) Error: Unable to use database “/var/lib/vnstat/eth0” or
backup database “/var/lib/vnstat/.eth0”.
[ 0 security updates available, 48 updates total: apt upgrade ]
Last check: 2023-11-25 16:01
Last login: Sat Nov 25 10:57:35 2023 from 192.168.1.190
mks@mkspi:~$ lsusb -v
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 5.16
iManufacturer 3 Linux 5.16.20-rockchip64 xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 xhci-hcd.0.auto
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 1
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
bHubDecLat 0.0 micro seconds
wHubDelay 0 nano seconds
DeviceRemovable 0x00
Hub Port Status:
Port 1: 0000.02b0 5Gbps power Rx.Detect RESET
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x000f
bNumDeviceCaps 1
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x02
Latency Tolerance Messages (LTM) Supported
wSpeedsSupported 0x0008
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
can’t get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 5.16
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
TT think time 8 FS bits
bPwrOn2PwrGood 10 * 2 milli seconds
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
can’t get device qualifier: Resource temporarily unavailable
Self Powered
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
idProduct 0x0001 1.1 root hub
bcdDevice 5.16
iManufacturer 3 Linux 5.16.20-rockchip64 ohci_hcd
iProduct 2 Generic Platform OHCI controller
iSerial 1 ff5d0000.usb
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
bPwrOn2PwrGood 2 * 2 milli seconds
Hub Port Status:
Self Powered
Bus 002 Device 003: ID 1a86:e5e3 QinHeng Electronics
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 0.01
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1a86 QinHeng Electronics
idProduct 0xe5e3
bcdDevice 0.00
iManufacturer 1 wch.cn
iProduct 2 USB2IIC_CTP_CONTROL
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 64mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 455
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
Device Status: 0x0000
(Bus Powered)
Bus 002 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idVendor 0x1a40 Terminus Technology Inc.
idProduct 0x0101 Hub
bcdDevice 1.11
iManufacturer 0
iProduct 1 USB 2.0 Hub
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
wHubCharacteristic 0x0000
Ganged power switching
Ganged overcurrent protection
bHubContrCurrent 100 milli Ampere
Hub Port Status:
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0103 power enable connect
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.16
iManufacturer 3 Linux 5.16.20-rockchip64 ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 ff5c0000.usb
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0009
Per-port power switching
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Self Powered
Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idProduct 0x7523 HL-340 USB-Serial adapter
bcdDevice 2.64
iManufacturer 0
iProduct 2 USB Serial
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0027
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 482mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 1
bInterfaceProtocol 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 1
(Bus Powered)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.16
iManufacturer 3 Linux 5.16.20-rockchip64 dwc2_hsotg
iProduct 2 DWC OTG Controller
iSerial 1 ff580000.usb
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
bPwrOn2PwrGood 1 * 2 milli seconds
Hub Port Status:
Port 1: 0000.0103 power enable connect
Self Powered
mks@mkspi:~$ ls /dev/serial/by-id
usb-1a86_USB_Serial-if00-port0
Also, i replaced the usb cable.
I’ll rewrite the image to the emmc tomorrow, i forgot the adapter at work. Thanks!
mighty1
November 28, 2023, 6:54am
4
I’ve reinstalled the image, still no luck. @sovol3d i’m waiting for some guidelines or an answer to my email. I’m still open to try suggestions, if one has them. Or maybe i’m doing something wrong.
