Hello, friends of 3D printing! ![]()
My Mianboard MCU is no longer recognised. After extensive personal research, I have now reached the end of my tether and am turning to the collective knowledge of this forum in the hope of finding a solution ![]()
This is actually the last step I can think of before I finally despair.
I actually run Klipper Mainline on my SV08. Why βactuallyβ? Klipper greeted me with the message that the MCU is no longer accessible (mcu βmcuβ: Unable to connect).
System (EMMC flashed)
Host (aarch64, 64-bit)
OS: Debian GNU/Linux 11 (bullseye)
BTT-CB1 2.3.4 Bullseye with Linux 5.16.17-sun50iw9
Klipper v0.13.0-514
After quite a bit of research, I found out that my MCU can no longer be found in Linux either.
biqu@sovolsv08:\~$ ls /dev/serial/by-id/
usb-katapult_stm32f103xe_52FF6E067167485753191787-if00
usb-Klipper_rp2040_5044505930A3761C-if00
usb-Klipper_stm32f042x6_0F001400115330374E333320-if00
biqu@sovolsv08:\~$ lsusb
Bus 003 Device 004: ID 1d50:614e OpenMoko, Inc. stm32f042x6
Bus 003 Device 003: ID 1d50:614e OpenMoko, Inc. rp2040
Bus 005 Device 002: ID 1d50:6177 OpenMoko, Inc. stm32f103xe
Definition
SV08 Toolhead (STM32F103)
/dev/serial/by-id/usb-katapult_stm32f103xe_52FF6E067167485753191787-if00
lsusb: ID 1d50:6177 OpenMoko, Inc. stm32f103xeKlipper Expansion Board (STM32F042)
/dev/serial/by-id/usb-Klipper_stm32f042x6_0F001400115330374E333320-if00
lsusb: ID 1d50:614e OpenMoko, Inc. stm32f042x6BTT Eddy (RP2040)
/dev/serial/by-id/usb-Klipper_rp2040_5044505930A3761C-if00
lsusb: ID 1d50:614e OpenMoko, Inc. rp2040
SV08 Mainboard (STM32F103) - missing, added manually for the forum
from my printer.cfg: stm32f103xe_30FFD7053347543032621651-if00
Now, to be on the safe side, I wanted to update the mainboardβs firmware to the same version, as I only installed Eddy Duo yesterday (wired and flashed, thatβs all thatβs possible at the moment). I connected to the mainboard using an St-Link v2 and the STM32CubeProgramme (wiring checked several times). I simply cannot connect to the motherboard:
Logfile (STM32CubeProgramme)
01:01:39 : UR connection mode is defined with the HWrst reset mode
01:01:39 : ST-LINK SN : 37FF71064E573β¦
01:01:39 : ST-LINK FW : V2J46S7
01:01:39 : Board : β
01:01:39 : Voltage : 3.23V
01:01:39 : Error: Unable to get core ID
01:01:39 : Error: Cannot connect to access port 0! If you are trying to connect to a device with TrustZone enabled, please try to connect with HotPlug mode. If you are trying to connect to a device that supports Debug Authentication with a certificate or password, please open your device using it.
As you can see, Iβm going round in circles
Help.
//ErgΓ€nzung/Edit
If I disconnect all devices and try to list them (lsusb and /dev/serial/by-id/), the list is accordingly empty. So not even the motherboard or its Stm chip is recognised.
2026-01-31T00:00:00Z
