SV07 Plus boot issues
Hi Community,
i have issues with my SV07 Plus after a failed update. I bough an MKS emmc adapter and flashed the emmc again via Sovol instructions and also with this image(GitHub - TomasOlsson/BrickedSv07-Sv07Plus: This is just for users that have bricked their Sovol Sv07 printer.), however this does not seem to solve my issues. I constatnly get stuck during boot. I was able to connect via serial and get a common freeze of the device after the RPC:
[    1.954451] random: fast init done
[    1.999271] rk808-rtc rk808-rtc: registered as rtc0
[    2.002282] rk808-rtc rk808-rtc: setting system clock to 2016-01-21T08:50:06 UTC (1453366206)
[    2.007224] genpd_dev_pm_attach: return 0
[    2.010194] genpd_dev_pm_attach: return 0
[    2.010875] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    2.016561] genpd_dev_pm_attach: return 0
[    2.018126] sdhci: Secure Digital Host Controller Interface driver
[    2.019238] sdhci: Copyright(c) Pierre Ossman
[    2.019673] Synopsys Designware Multimedia Card Interface Driver
[    2.023436] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.023701] genpd_dev_pm_attach: return 0
[    2.023953] genpd_dev_pm_attach: return 0
[    2.024479] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[    2.024866] dwmmc_rockchip ff510000.mmc: IDMAC supports 32-bit address mode.
[    2.024942] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[    2.025632] dwmmc_rockchip ff510000.mmc: Using internal DMA controller.
[    2.026243] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[    2.026849] dwmmc_rockchip ff510000.mmc: Version ID is 270a
[    2.027115] genpd_dev_pm_attach: return 0
[    2.027574] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    2.028039] dwmmc_rockchip ff510000.mmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    2.031239] dwmmc_rockchip ff510000.mmc: allocated mmc-pwrseq
[    2.031785] mmc_host mmc1: card is non-removable.
[    2.031816] mmc_host mmc2: card is non-removable.
[    2.032737] ledtrig-cpu: registered to indicate activity on CPUs
[    2.035909] hid: raw HID events driver (C) Jiri Kosina
[    2.036736] usbcore: registered new interface driver usbhid
[    2.037323] usbhid: USB HID core driver
[    2.040771] genpd_dev_pm_attach: return 0
[    2.041486] genpd_dev_pm_attach: return 0
[    2.044457] genpd_dev_pm_attach: return 0
[    2.045651] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.046120] drop_monitor: Initializing network drop monitor service
[    2.048408] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.048837] NET: Registered PF_INET6 protocol family
[    2.053454] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    2.073350] usb 1-1: new full-speed USB device number 2 using dwc2
[    2.078521] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.081670] mmc2: new high speed SDIO card at address 0001
[    2.137497] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    2.210293] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    2.211090] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.211759] usb 2-1: Product: USB 2.0 Hub
[    2.213434] hub 2-1:1.0: USB hub found
[    2.214053] hub 2-1:1.0: 4 ports detected
[    2.282613] usb 1-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[    2.283410] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.284078] usb 1-1: Product: USB Serial
[    2.621402] usb 2-1.4: new full-speed USB device number 3 using ehci-platform
[    2.741774] dwmmc_rockchip ff520000.mmc: Successfully tuned phase to 65
[    2.742784] mmc1: new HS200 MMC card at address 0001
[    2.746396] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    2.753516]  mmcblk1: p1 p2
[    2.757698] mmcblk1boot0: mmc1:0001 8GTF4R 4.00 MiB
[    2.765495] mmcblk1boot1: mmc1:0001 8GTF4R 4.00 MiB
[    2.772083] mmcblk1rpmb: mmc1:0001 8GTF4R 512 KiB, chardev (241:0)
[    2.851419] usb 2-1.4: New USB device found, idVendor=1a86, idProduct=e5e3, bcdDevice= 0.00
[    2.852250] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.852943] usb 2-1.4: Product: USB2IIC_CTP_CONTROL
[    2.853472] usb 2-1.4: Manufacturer: wch.cn
[    2.864383] input: wch.cn USB2IIC_CTP_CONTROL as /devices/platform/ff5c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:1A86:E5E3.0001/input/input0
[    2.866660] hid-generic 0003:1A86:E5E3.0001: input,hidraw0: USB HID v1.00 Device [wch.cn USB2IIC_CTP_CONTROL] on usb-ff5c0000.usb-1.4/input0
[    3.525273] random: crng init done
[    4.426934] Freeing initrd memory: 18984K
[    4.496534] Segment Routing with IPv6
[    4.497084] In-situ OAM (IOAM) with IPv6
[    4.497679] NET: Registered PF_PACKET protocol family
[    4.498463] 8021q: 802.1Q VLAN Support v1.8
[    4.498973] Key type dns_resolver registered
[    4.501472] registered taskstats version 1
[    4.501902] Loading compiled-in X.509 certificates
[    4.508930] Loaded X.509 cert 'Build time autogenerated kernel key: 0943f0a551433e668ec738d91ef2418b2d3186bf'
[    4.515684] zswap: loaded using pool zstd/z3fold
[    4.518040] Key type ._fscrypt registered
[    4.518450] Key type .fscrypt registered
[    4.518814] Key type fscrypt-provisioning registered
[    4.523567] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    4.524865] Key type encrypted registered
[    4.525363] AppArmor: AppArmor sha1 policy hashing enabled
[    4.612252] genpd_dev_pm_attach: return 0
[    4.614066] genpd_dev_pm_attach: return 0
[    4.615515] genpd_dev_pm_attach: return 0
[    4.616834] genpd_dev_pm_attach: return 0
[    4.619611] genpd_dev_pm_attach: return 0
[    4.633165] genpd_dev_pm_attach: return 0
[    4.635890] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
[    4.637695] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    4.639746] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.641648] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
[    5.298446] bootsplash: Loading splash file (247678368 bytes)
[    5.298646] bootsplash: Loaded (247678368 bytes, 2 pics, 215 blobs).
[    5.385755] Console: switching to colour frame buffer device 100x30
[    5.420773] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    5.422654] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    5.426447] genpd_dev_pm_attach: return 0
[    5.426532] rk3328-dmc ff780000.dmc: current ATF version 0x101
[    5.426783] genpd_dev_pm_attach: return 0
[    5.428579] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode.
[    5.429962] dwmmc_rockchip ff500000.mmc: Using internal DMA controller.
[    5.430719] dwmmc_rockchip ff500000.mmc: Version ID is 270a
[    5.431466] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.434522] of_cfs_init
[    5.435002] of_cfs_init: OK
[    5.446463] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.464445] Freeing unused kernel memory: 4352K
[    5.464610] Run /init as init process
[    6.460644] genpd_dev_pm_attach: return 0
[    6.460698] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
[    6.548508] genpd_dev_pm_attach: return 0
[    6.549442] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned
[    6.561524] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    6.808038] genpd_dev_pm_attach: return 0
[    6.808141] rk_gmac-dwmac ff550000.ethernet: IRQ eth_wake_irq not found
[    6.808159] rk_gmac-dwmac ff550000.ethernet: IRQ eth_lpi not found
[    6.808487] rk_gmac-dwmac ff550000.ethernet: PTP uses main clock
[    6.809024] rk_gmac-dwmac ff550000.ethernet: clock input or output? (output).
[    6.809057] rk_gmac-dwmac ff550000.ethernet: Can not read property: tx_delay.
[    6.809067] rk_gmac-dwmac ff550000.ethernet: set tx_delay to 0x30
[    6.809084] rk_gmac-dwmac ff550000.ethernet: Can not read property: rx_delay.
[    6.809094] rk_gmac-dwmac ff550000.ethernet: set rx_delay to 0x10
[    6.809145] rk_gmac-dwmac ff550000.ethernet: integrated PHY? (yes).
[    6.809473] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
[    6.809534] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
[    6.814636] rk_gmac-dwmac ff550000.ethernet: init for RMII
[    6.858413] rk_gmac-dwmac ff550000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    6.859368] rk_gmac-dwmac ff550000.ethernet:         DWMAC1000
[    6.860090] rk_gmac-dwmac ff550000.ethernet: DMA HW capability register supported
[    6.860967] rk_gmac-dwmac ff550000.ethernet: RX Checksum Offload Engine supported
[    6.862110] rk_gmac-dwmac ff550000.ethernet: COE Type 2
[    6.862850] rk_gmac-dwmac ff550000.ethernet: TX Checksum insertion supported
[    6.863716] rk_gmac-dwmac ff550000.ethernet: Wake-Up On Lan supported
[    6.864761] rk_gmac-dwmac ff550000.ethernet: Normal descriptors
[    6.865598] rk_gmac-dwmac ff550000.ethernet: Ring mode enabled
[    6.866366] rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    7.314176] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: data=writeback. Quota mode: none.
[    8.248317] systemd[1]: System time before build time, advancing clock.
[    8.285236] systemd[1]: Inserted module 'autofs4'
[    8.372038] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    8.375898] systemd[1]: Detected architecture arm64.
[    8.416594] systemd[1]: Set hostname to <mkspi>.
[    8.755225] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    9.287094] systemd[1]: Configuration file /lib/systemd/system/makerbase-soft-shutdown.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    9.288876] systemd[1]: Configuration file /lib/systemd/system/makerbase-soft-shutdown.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    9.527169] systemd[1]: Unnecessary job for /sys/subsystem/net/devices/wlan0 was removed.
[    9.532144] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.535697] systemd[1]: Listening on Journal Socket.
[    9.538418] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.554362] systemd[1]: Mounting Huge Pages File System...
[   10.092879] RPC: Registered named UNIX socket transport module.
[   10.093715] RPC: Registered udp transport module.
[   10.094333] RPC: Registered tcp transport module.
[   10.094919] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.110126] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
Not so sure where to go from here. Any help would be great.
Chris
I used the image from
Works perfect. Armbian updates work 100%, Klipper updates work 100%
