No boot Klipperscreen
Hello, on my Sovol 07 Plus the Klipperscreen no longer starts up after updating to the latest firmware? The clipper screen goes to the logo then the screen goes dark. I ask for help. Printer was purchased from you last year.
I was able to read the following with Putty, but then the board kicked me out
DDR version 1.16 20190528
In
DDR3
333MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:1
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 232
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 11425
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt…
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xaecb0
RunBL31 0x40000
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(debug):403e0b816
NOTICE: BL31: Built : 14:13:08, Aug 11 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2021.07-armbian (Feb 22 2023 - 19:51:46 +0800)
Model: Makerbase mkspi
DRAM: 1022 MiB
PMIC: RK8050 (on=0x80, off=0x04)
MMC: mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC… Card did not respond to voltage select! : -110
*** Warning - No block device, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
Net: eth1: ethernet@ff550000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
334 bytes read in 3 ms (108.4 KiB/s)
1: Armbian
Retrieving file: /uInitrd
19443666 bytes read in 441 ms (42 MiB/s)
Retrieving file: /Image
30327296 bytes read in 688 ms (42 MiB/s)
append: root=UUID=4148ed1f-7865-4fd6-84b0-9564c15dbeac console=uart8250,mmio32,0xff130000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian
Retrieving file: /dtb/rockchip/rk3328-roc-cc.dtb
64630 bytes read in 5 ms (12.3 MiB/s)
Moving Image from 0x2080000 to 0x2200000, end=3f90000
Loading init Ramdisk from Legacy Image at 06000000 …
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 19443602 Bytes = 18.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to 3cc9e000, end 3df28f92 … OK
Loading Device Tree to 000000003cc8b000, end 000000003cc9dc75 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.16.20-rockchip64 (root@menson-virtual-machine) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP PREEMPT Fri Aug 4 13:50:11 CST 2023
[ 0.000000] Machine model: Firefly roc-rk3328-cc
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options ‘’)
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000003fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x3fdb2040-0x3fdb3fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000200000-0x000000003fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000200000-0x000000003fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000003fffffff]
[ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.000000] cma: Reserved 128 MiB at 0x0000000034c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 29 pages/cpu s80856 r8192 d29736 u118784
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 257544
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: root=UUID=4148ed1f-7865-4fd6-84b0-9564c15dbeac console=uart8250,mmio32,0xff130000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 845376K/1046528K available (15936K kernel code, 2672K rwdata, 6548K rodata, 4352K init, 592K bss, 70080K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x808/0x9ec with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002221] Console: colour dummy device 80x25
[ 0.002647] printk: console [tty0] enabled
[ 0.003038] printk: bootconsole [uart8250] disabled
[ 0.003642] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.003692] pid_max: default: 32768 minimum: 301
[ 0.003867] LSM: Security Framework initializing
[ 0.003946] Yama: becoming mindful.
[ 0.004128] AppArmor: AppArmor initialized
[ 0.004320] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.004368] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.008300] rcu: Hierarchical SRCU implementation.
[ 0.011582] EFI services will not be available.
[ 0.012370] smp: Bringing up secondary CPUs …
[ 0.013580] Detected VIPT I-cache on CPU1
[ 0.013698] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.015085] Detected VIPT I-cache on CPU2
[ 0.015193] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.016624] Detected VIPT I-cache on CPU3
[ 0.016731] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.016950] smp: Brought up 1 node, 4 CPUs
[ 0.017078] SMP: Total of 4 processors activated.
[ 0.017103] CPU features: detected: 32-bit EL0 Support
[ 0.017125] CPU features: detected: 32-bit EL1 Support
[ 0.017156] CPU features: detected: CRC32 instructions
[ 0.036872] CPU: All CPU(s) started at EL2
[ 0.037014] alternatives: patching kernel code
[ 0.039549] devtmpfs: initialized
[ 0.062777] Registered cp15_barrier emulation handler
[ 0.062851] Registered setend emulation handler
[ 0.063275] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.063366] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.070292] pinctrl core: initialized pinctrl subsystem
[ 0.071549] DMI not present or invalid.
[ 0.072561] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.077718] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.079352] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.082624] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.082810] audit: initializing netlink subsys (disabled)
[ 0.083325] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[ 0.084994] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.085013] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.085048] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.085073] thermal_sys: Registered thermal governor ‘user_space’
[ 0.085703] cpuidle: using governor menu
[ 0.086216] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.086463] ASID allocator initialised with 65536 entries
[ 0.088487] Serial: AMBA PL011 UART driver
[ 0.111229] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
[ 0.139667] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
[ 0.141206] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
[ 0.142560] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
[ 0.143980] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
[ 0.171698] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.171762] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.171795] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.171827] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.173267] cryptd: max_cpu_qlen set to 1000
[ 0.241469] raid6: neonx8 gen() 1047 MB/s
[ 0.309651] raid6: neonx8 xor() 775 MB/s
[ 0.377898] raid6: neonx4 gen() 1052 MB/s
[ 0.446005] raid6: neonx4 xor() 769 MB/s
[ 0.514168] raid6: neonx2 gen() 1012 MB/s
[ 0.582304] raid6: neonx2 xor() 710 MB/s
[ 0.650466] raid6: neonx1 gen() 888 MB/s
[ 0.718600] raid6: neonx1 xor() 608 MB/s
[ 0.786748] raid6: int64x8 gen() 744 MB/s
[ 0.854961] raid6: int64x8 xor() 392 MB/s
[ 0.923074] raid6: int64x4 gen() 830 MB/s
[ 0.991219] raid6: int64x4 xor() 424 MB/s
[ 1.059376] raid6: int64x2 gen() 708 MB/s
[ 1.127512] raid6: int64x2 xor() 375 MB/s
[ 1.195655] raid6: int64x1 gen() 526 MB/s
[ 1.263829] raid6: int64x1 xor() 274 MB/s
[ 1.263858] raid6: using algorithm neonx4 gen() 1052 MB/s
[ 1.263882] raid6: … xor() 769 MB/s, rmw enabled
[ 1.263906] raid6: using neon recovery algorithm
[ 1.267042] iommu: Default domain type: Translated
[ 1.267092] iommu: DMA domain TLB invalidation policy: strict mode
[ 1.270537] vgaarb: loaded
[ 1.271492] SCSI subsystem initialized
[ 1.272666] usbcore: registered new interface driver usbfs
[ 1.272789] usbcore: registered new interface driver hub
[ 1.272888] usbcore: registered new device driver usb
[ 1.273819] pps_core: LinuxPPS API ver. 1 registered
[ 1.273852] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.273907] PTP clock support registered
[ 1.274281] EDAC MC: Ver: 3.0.0
[ 1.276776] NetLabel: Initializing
[ 1.276827] NetLabel: domain hash size = 128
[ 1.276851] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.277004] NetLabel: unlabeled traffic allowed by default
[ 1.277986] clocksource: Switched to clocksource arch_sys_counter
[ 1.385453] VFS: Disk quotas dquot_6.6.0
[ 1.385617] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.387380] AppArmor: AppArmor Filesystem Enabled
[ 1.402472] NET: Registered PF_INET protocol family
[ 1.402813] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.404715] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 1.404876] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.405174] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 1.405404] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.405699] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.405789] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.406234] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.406314] NET: Registered PF_XDP protocol family
[ 1.406353] PCI: CLS 0 bytes, default 64
[ 1.407189] Trying to unpack rootfs image as initramfs…
[ 1.415339] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.416333] kvm [1]: IPA Size Limit: 40 bits
[ 1.419075] kvm [1]: vgic interrupt IRQ9
[ 1.419479] kvm [1]: Hyp mode initialized successfully
[ 1.423546] Initialise system trusted keyrings
[ 1.423676] Key type blacklist registered
[ 1.424193] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[ 1.437023] zbud: loaded
[ 1.440341] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.442065] fuse: init (API version 7.35)
[ 1.444847] integrity: Platform Keyring initialized
[ 1.518634] xor: measuring software checksum speed
[ 1.526906] 8regs : 1218 MB/sec
[ 1.534076] 32regs : 1401 MB/sec
[ 1.543361] arm64_neon : 1073 MB/sec
[ 1.543416] xor: using function: 32regs (1401 MB/sec)
[ 1.543458] Key type asymmetric registered
[ 1.543485] Asymmetric key parser ‘x509’ registered
[ 1.543880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.544397] io scheduler mq-deadline registered
[ 1.544452] io scheduler kyber registered
[ 1.544904] io scheduler bfq registered
[ 1.571332] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.571413] dma-pl330 ff1f0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.578304] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.584573] ff110000.serial: ttyS0 at MMIO 0xff110000 (irq = 19, base_baud = 1500000) is a 16550A
[ 1.586678] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 20, base_baud = 1500000) is a 16550A
[ 1.680737] printk: console [ttyS2] enabled
[ 1.683319] Serial: AMBA driver
[ 1.685828] rockchip-vop ff370000.vop: Adding to iommu group 2
[ 1.711296] loop: module loaded
[ 1.718327] Enter rockchip_spi_probe, slave_mode:0
[ 1.718916] Enter rockchip_spi_probe, spiclk:32875264
[ 1.719556] Enter rockchip_spi_probe, rs->freq:48000000
[ 1.720060] rockchip_spi_probe, ctlr->min_speed_hz:732, ctlr->max_speed_hz:24000000, rs->freq:48000000
[ 1.721850] enter spi_setup
[ 1.722190] spi_setup, spi->max_speed_hz:5000000, spi->controller->max_speed_hz:24000000
[ 1.722956] exit spi_setup, max_speed_hz:5000000
[ 1.724661] enter spi_match_device
[ 1.725014] spi_match_device:of_driver_match_device
[ 1.725704] Enter spi_probe, dev->of_node:/spi@ff190000/spi_for_cs2@0
[ 1.726374] spi_probe, of_clk_set_defaults:0
[ 1.726811] spi_probe, dev_pm_domain_attach:0
[ 1.727577] spi_probe, sdrv->probe:0
[ 1.731318] tun: Universal TUN/TAP device driver, 1.6
[ 1.733547] thunder_xcv, ver 1.0
[ 1.734056] thunder_bgx, ver 1.0
[ 1.734499] nicpf, ver 1.0
[ 1.736097] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.736570] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.737227] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.737726] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.738361] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.738942] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.739928] sky2: driver version 1.30
[ 1.741415] VFIO - User Level meta-driver version: 0.3
[ 1.746016] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[ 1.747025] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[ 1.760885] dwc2 ff580000.usb: DWC OTG Controller
[ 1.761395] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 1.762184] dwc2 ff580000.usb: irq 49, io mem 0xff580000
[ 1.763120] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[ 1.763897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.764557] usb usb1: Product: DWC OTG Controller
[ 1.764995] usb usb1: Manufacturer: Linux 5.16.20-rockchip64 dwc2_hsotg
[ 1.765601] usb usb1: SerialNumber: ff580000.usb
[ 1.767238] hub 1-0:1.0: USB hub found
[ 1.767705] hub 1-0:1.0: 1 port detected
[ 1.770367] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.771029] ehci-pci: EHCI PCI platform driver
[ 1.771547] ehci-platform: EHCI generic platform driver
[ 1.775023] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 1.775631] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 1.776619] ehci-platform ff5c0000.usb: irq 50, io mem 0xff5c0000
[ 1.790055] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.791228] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[ 1.792013] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.792681] usb usb2: Product: EHCI Host Controller
[ 1.793133] usb usb2: Manufacturer: Linux 5.16.20-rockchip64 ehci_hcd
[ 1.793726] usb usb2: SerialNumber: ff5c0000.usb
[ 1.795352] hub 2-0:1.0: USB hub found
[ 1.795841] hub 2-0:1.0: 1 port detected
[ 1.797110] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.797742] ohci-pci: OHCI PCI platform driver
[ 1.798353] ohci-platform: OHCI generic platform driver
[ 1.799721] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 1.800385] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 1.801392] ohci-platform ff5d0000.usb: irq 51, io mem 0xff5d0000
[ 1.866633] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16
[ 1.867438] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.868112] usb usb3: Product: Generic Platform OHCI controller
[ 1.868666] usb usb3: Manufacturer: Linux 5.16.20-rockchip64 ohci_hcd
[ 1.869268] usb usb3: SerialNumber: ff5d0000.usb
[ 1.871124] hub 3-0:1.0: USB hub found
[ 1.871649] hub 3-0:1.0: 1 port detected
[ 1.874490] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.875078] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[ 1.876140] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[ 1.877159] xhci-hcd xhci-hcd.0.auto: irq 52, io mem 0xff600000
[ 1.879210] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[ 1.880013] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.880693] usb usb4: Product: xHCI Host Controller
[ 1.881152] usb usb4: Manufacturer: Linux 5.16.20-rockchip64 xhci-hcd
[ 1.881749] usb usb4: SerialNumber: xhci-hcd.0.auto
[ 1.883569] hub 4-0:1.0: USB hub found
[ 1.884075] hub 4-0:1.0: 1 port detected
[ 1.885326] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.885895] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[ 1.886737] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.887587] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.888660] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
[ 1.889460] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.890171] usb usb5: Product: xHCI Host Controller
[ 1.890645] usb usb5: Manufacturer: Linux 5.16.20-rockchip64 xhci-hcd
[ 1.891240] usb usb5: SerialNumber: xhci-hcd.0.auto
[ 1.893033] hub 5-0:1.0: USB hub found
[ 1.893563] hub 5-0:1.0: 1 port detected
[ 1.895266] usbcore: registered new interface driver usb-storage
[ 1.899845] mousedev: PS/2 mouse device common for all mice
[ 1.901327] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[ 1.902021] SPI driver ads7846 has no spi_device_id for ti,ads7843
[ 1.902612] SPI driver ads7846 has no spi_device_id for ti,ads7845
[ 1.903182] SPI driver ads7846 has no spi_device_id for ti,ads7873
[ 1.903845] enter spi_match_device
[ 1.904198] of_driver_match_device failed
[ 1.904572] dev_node:/spi@ff190000/spi_for_cs2@0, drv_name:ti,tsc2046
[ 1.907151] i2c_dev: i2c /dev entries driver
[ 1.913826] rk808 1-0018: chip id: 0x8050
[ 1.925444] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.926472] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.927100] rk808-regulator rk808-regulator: max buck steps per change: 8
[ 1.949830] random: fast init done
[ 1.996698] rk808-rtc rk808-rtc: registered as rtc0
[ 1.999777] rk808-rtc rk808-rtc: setting system clock to 2016-01-21T08:52:15 UTC (1453366335)
[ 2.007993] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[ 2.013604] sdhci: Secure Digital Host Controller Interface driver
[ 2.014270] sdhci: Copyright(c) Pierre Ossman
[ 2.014694] Synopsys Designware Multimedia Card Interface Driver
[ 2.017112] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.018309] dwmmc_rockchip ff510000.mmc: IDMAC supports 32-bit address mode.
[ 2.019060] dwmmc_rockchip ff510000.mmc: Using internal DMA controller.
[ 2.019224] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[ 2.019704] dwmmc_rockchip ff510000.mmc: Version ID is 270a
[ 2.019823] dwmmc_rockchip ff510000.mmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[ 2.020584] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[ 2.021477] dwmmc_rockchip ff510000.mmc: allocated mmc-pwrseq
[ 2.022085] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[ 2.022433] mmc_host mmc2: card is non-removable.
[ 2.023181] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[ 2.027376] mmc_host mmc1: card is non-removable.
[ 2.028082] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.031343] hid: raw HID events driver (C) Jiri Kosina
[ 2.032159] usbcore: registered new interface driver usbhid
[ 2.032693] usbhid: USB HID core driver
[ 2.034158] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.040729] drop_monitor: Initializing network drop monitor service
[ 2.042859] NET: Registered PF_INET6 protocol family
[ 2.043661] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.058037] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.064276] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.067189] mmc2: new high speed SDIO card at address 0001
[ 2.070032] usb 1-1: new full-speed USB device number 2 using dwc2
[ 2.135348] mmc_host mmc1: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 2.218912] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 2.219707] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.220367] usb 2-1: Product: USB 2.0 Hub
[ 2.222179] hub 2-1:1.0: USB hub found
[ 2.222803] hub 2-1:1.0: 4 ports detected
[ 2.279221] usb 1-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 2.280023] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.280686] usb 1-1: Product: USB Serial
[ 2.770374] dwmmc_rockchip ff520000.mmc: Successfully tuned phase to 262
[ 2.771339] mmc1: new HS200 MMC card at address 0001
[ 2.774222] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 2.779935] mmcblk1: p1 p2
[ 2.782910] mmcblk1boot0: mmc1:0001 8GTF4R 4.00 MiB
[ 2.788830] mmcblk1boot1: mmc1:0001 8GTF4R 4.00 MiB
[ 2.794052] mmcblk1rpmb: mmc1:0001 8GTF4R 512 KiB, chardev (241:0)
[ 3.530606] random: crng init done
[ 4.427002] Freeing initrd memory: 18984K
[ 4.501026] Segment Routing with IPv6
[ 4.501608] In-situ OAM (IOAM) with IPv6
[ 4.502244] NET: Registered PF_PACKET protocol family
[ 4.503104] 8021q: 802.1Q VLAN Support v1.8
[ 4.503678] Key type dns_resolver registered
[ 4.506608] registered taskstats version 1
[ 4.507111] Loading compiled-in X.509 certificates
[ 4.514439] Loaded X.509 cert ‘Build time autogenerated kernel key: 0943f0a551433e668ec738d91ef2418b2d3186bf’
[ 4.520670] zswap: loaded using pool zstd/z3fold
[ 4.523115] Key type ._fscrypt registered
[ 4.523523] Key type .fscrypt registered
[ 4.523885] Key type fscrypt-provisioning registered
[ 4.528670] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[ 4.530045] Key type encrypted registered
[ 4.530497] AppArmor: AppArmor sha1 policy hashing enabled
[ 4.633154] rockchip-drm display-subsystem: bound ff370000.vop (ops vop_component_ops)
[ 4.634599] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 4.636629] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 4.638547] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops dw_hdmi_rockchip_ops)
I’m having very similar problem, also an SV07+. Maybe even a bit worse. Where you load a retrieved image a few lines before the Ramdisk section, mine fails for “failure to retrieve kernel.” After that, nothing but errors and BOOTP broadcasts.
This happened when I shut down the printer in preparation to upload the new firmware. Never even inserted the USB drive to try it because the screen never came back on.
Failed to load ‘/Image’
Skipping Armbian for failure retrieving kernel
SCRIPT FAILED: continuing…
Scanning disk mmc@ff500000.blk…
Disk mmc@ff500000.blk not ready
Scanning disk mmc@ff520000.blk…
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
starting USB…
Bus usb@ff5c0000: USB EHCI 1.00
Bus usb@ff5d0000: USB OHCI 1.0
Bus usb@ff580000: USB DWC2
scanning bus usb@ff5c0000 for devices… 3 USB Device(s) found
scanning bus usb@ff5d0000 for devices… 1 USB Device(s) found
canning bus usb@ff580000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
VERSION command returns the following:
aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025
GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209
Congrats, you will now need to get the mks emmc v2.0 adapter to flash the latest image…
Did it today three times :unamused:
You will get the image from the Sovol Documents Website.
And this is the direct link to the correct Download.
Ah, when you finished flashing.
Block these apt packages over ssh:
apt-mark hold linux-image-edge-rockchip64 linux-dtb-edge-rockchip64 linux-u-boot-mkspi-edge
Be patient with:
apt update && apt upgrade -y
It will upgrade 128 packages and took me 20 minutes to update.
Also remove the vnstat eth0 file:
sudo rm -rf /var/lib/vnstat/eth0
Greetings DrR00T90
How does on “remove” those files?
I’ve tried your procedure but I got:
mks@mkspi:~$ sudo apt-mark hold linux-image-edge-rockchip64 linux-dtb-edge-rockc hip64 linux-u-boot-mkspi-edge
linux-image-edge-rockchip64 set on hold.
linux-dtb-edge-rockchip64 set on hold.
linux-u-boot-mkspi-edge set on hold.
mks@mkspi:~$ sudo apt update
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 Index of /debian buster InRelease
Hit:3 Index of /debian buster-updates InRelease
Hit:4 Index of /debian buster-backports InRelease
Ign:5 mirrors.dotsrc.org buster InRelease
Err:6 Index of /apt/ buster Release
404 Not Found [IP: 65.21.120.247 80]
Reading package lists… Done
E: The repository ‘http://apt.armbian.com buster Release’ no longer has a Releas e file.
N: Updating from such a repository can’t be done securely, and is therefore disa bled by default.
N: See apt-secure(8) manpage for repository creation and user configuration deta ils.
mks@mkspi:~$
Oh, that’s unfortunate. The armbian version running on the Makerbase board is based on Debian 10, aka “Buster”:
mks@mkspi:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 10 (buster)
Release:	10
Codename:	buster
This is now an old version, the current version of Debian is 12 aka “bookworm”.
It seems like armbian have switched to bookworm, and removing buster from apt.armbian.com. I have only checked a few mirrors (open in your web browser, the look in the dists folder), but there is only bookworm, bullseye, trixie and sid there now.
I wonder how we will be able to upgrade our Makerbase boards now?
