Habe den SV07 Plus im August gekauft. Nun Tranportiert der Filament Motor nicht mehr richtig.
Der motor brummt und am das Rad vorne dreht nicht mehr richtig. Was ist möglich
Wolfgang
Sounds like you might have a nozzle clog or filament stuck in the extruder gears.
Have you looked into these…??
Yes, everything is done. The motor hums sometimes and if you touch the front wheel lightly, the motor shakes and makes humming noises.
This means that the filament is not transported. No power
Open a ticket with Sovol: info@sovol3d.com
They will probably ask you for pics & a video.
In addition to Lion’s good advice, here are a few other things you can check (if not done already)
- loose connector / damaged wiring to the motor (also check the other end of the wiring)
- loose extruder gear (it can turn without the axle on the motor turning)
