I am about to try my first Glow n Dark filament and have seen on some websites Glow n Dark should printed with a steel nozzle which leads to the question, why not use steel nozzle all the time.
Thoughts on this?
Thoughts on this?
That’s because it’s harder to print with a nozzle like that.
Higher temperature, fragile nozzle, nozzle to replace frequently, etc.
With a Hardened Steel Nozzle you will have to adjust the nozzle temp 5*-10* hotter for all filaments. You can use a standard brass nozzle to print GITD, it will just wear it out quicker.
