i haven’t used my printer in a long time and after trying to start a print it heats the bed and nozzel, then does an auto home, then it moves the x right for a split second and then the printer crashes and restart, no error no anything, i have no idea what might be causing it.
i am using cura slicer if that might help, i have also tried some full control gcode and while it maneges to move the x almost to the center the printer restarts anyway.
You can try adding a G28 command in the slicing software to ensure the printer homes before printing.and review the klippy.log file, which might provide specific error information that leads to the printer restarting. If you’re using Cura slicing software, ensure your start G-Code and end G-Code are compatible with Klipper. Some people find it necessary to delete or modify Cura’s default G-Code because it may no longer be suitable for Klipper.
