so as stated the printer runs through the auto leveling process than stops and freezes. updated firm ware on machine and slicer and nothing.
hi @jake sorry to read the trouble. Could you pls provide the machine type you are running for a further look?
In the meantime, could you pls reflash the firmware and try the leveling guide again? Here is the leveling tutorial for your reference.
- Firmware Downlaod: SV01 Pro V1.2.0.rar - Google Drive
- Firmware flash video tutorial: How to flash firmware for SOVOL SV01 PRO& Sovol SV06( Mainboard Firmware Needed Only) 3D Printer - YouTube
- Leveling tutorial: Bed Leveling Guide for Sovol SV01 Pro 3D Printer, more silent and quicker auto bed leveling! - YouTube
The printer type is Sovol svo3 .
So it is the svo3 printer and I have updated the firmware and still nothing. My unit has an updated touch screen. I had to flash the firmware originally so I did it the same as I had originally done. it has worked for months . just for further information i started a print and about 30 minutes into the print it failed so I cleared the bed plate and started the print again and this started happening.
Order # 61628
so the unit will no longer read the sd card.
It worked well for a few months but now it will no longer read the sd card.
I have reflashed the correct firmware multiple times.
I have bought new SD cards and tried to reformat them.
it will print from my computer if i use the usb cable but I can’t use sd cards.
I think the sd card reader is bad so my question is is it under warranty?
invoice-61628 (1).pdf (43.6 KB)
