I got my SV05 to work for a bit as long as i babysat it but i haven’t been able to print anything recently because of the bed leveling and the printer saving any of my settings. like pre heat settings changing to a lower temp needed for the filament I’m using. but most annoying is the leveling i did the paper test and saved the settings and it sorta worked for a few prints but i had to stop printing because the bed leveling set it self lower than the bed… making engrave the print pattern in the bed making impossible to print anyone know how to fix?
You should open a ticket at info@sovol3d.com with your order number and pics.
Good luck
