Poor prints after nozzle cleaning SV07+
Hello friends,
I’m quite new in 3d printing and last week I had to disassemble the print header because some filament was stuck. I was very careful and reassembled it.
But now I have very poor print experience. I already recalibrated everything. Here are some pictures before (white) and after (grey):
https://imgur.com/a/sv07-after-nozzle-cleaning-LF6IQdU
I’m stuck on getting the quality back again. Do you have some advise for me?
Thank you very much.
Have you tried a factory reset of the printer?
Tighten the tension screw a little…
then maybe your Z-Offset is a little off or your nozzle is clogged.
Can you take a picture of what you took apart..??
Did you just remove the nozzle or did you disassemble the extruder gears..??
Hello guys, I was on holiday so my answer is a little bit late.
@mich0111 thank you very much for your hint. I did not think about a factory reset but now I keep it in my head. Luckily my problem was solved by @Lion. After reassembling I didn’t tighten the tension screw enough. Attached you can see the new quality which is good enough for most prints. But if you have any idea for improvement, feel free to let me know or maybe link some other threads.
