Nozzle size in klipper printer.cfg or only in slicer settings?
Hello sovol users,
I have for pla used a 0.4 mm brass nozzle but i have all so the hard steel from sovol ordered with my printer 2x 0.4 mm 2x 0.6 mm 1x 0.8 mm 1x 1.0 mm see link…
On my printer.cfg file in the section extrude nozzle_diameter: 0.400 must i set it for use 0.600 for 0.6mm 0.800 for 0.8mm etc… or leave it alone there is no instruction but on orcal slicer a can set it to xxxx and from bras to steel etc. Please need more info about it.
Who can help me out with this.
[extruder]
max_extrude_only_distance: 100.0
step_pin: PD1
dir_pin: !PD0
enable_pin: !PD4
microsteps: 16
rotation_distance: 4.59 #4.6818
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PA4
#control: pid
pressure_advance:0.02
pressure_advance_smooth_time:0.035
max_extrude_cross_section:500
instantaneous_corner_velocity:10
max_extrude_only_velocity:2000
max_extrude_only_accel:10000
#pid_Kp=24.522
#pid_Ki=1.397
#pid_Kd=107.590
min_temp: 0
max_temp: 305
min_extrude_temp: 150
Based on the Klipper documentation here, you must set it.
In my own configuration (I have only a 0.4mm nozzle on my SV07 Plus) nozzle_diameter is set to 0.400.
