I’m attaching my modified version of SV08 Macro.cfg
This file allows the machine to perform the start print macro while maintaining the bed temp specified in the gcode without cycling down during the calibrations. I also verified that the calibrations can be completed after a cold soak by issuing the calibration commands and they default to 65 as expected.
I cleaned up some of the spelling errors elsewhere in the file. (targer vs. target, e_restract vs e_retract)
WARNING: I make no claims that this file is fit for use and AM NOT RESPONSIBLE for any damage it may cause. USE AT YOUR OWN RISK.
That being said,
config-20241229-171742.zip (3.8 KB)
I have tested with GCODE files specifying 55c, 65c, 85c and 120c bed temps. All complete the start macro while maintaining the specified bed temp throughout the start sequence.
NOTE: I have not upgraded to the new firmware, I have no idea if this has been corrected by Sovol. I did this because I couldn’t get my machine to maintain bed temp, even with the code edits described on Reddit and by gERGO on youtube.
