SV04 Initial Layer Bed Temperature
I am having trouble with the initial layer bed temperature. I set it in Cura and the g-code generated states: ;SETTING_3 \nmaterial_bed_temperature_layer_0 = 70,
However, when I go to print, it ignores this and just sets the bed to the regular bed temperature setting.
What do I need to do differently?
Which slicing software are you using and what’s the firmware version shown in the “printer info” menu on the screen? Could you upload the gcode file for analysis?
I am using Sovol Cura 1.3.0
The firmware on the printer is 1.1.0 and screen is 2.0
I cannot upload the file because only image extensions are allowed. .gcode is not in the allowed extension list. Is there another way to send you the file?
@ Sovol team: you should be aware of the problem. Everyone who uses your customized Cura version did. You can’t possibly have missed this if you’ve tested Cura and the SV04.
