Addressing the 65°C Heat Bed Temperature During Calibration
Since purchasing my SV08, I’ve encountered a recurring issue where the print bed heats up to 65°C during the calibration phase of every print. After searching for a solution without success, I decided to implement my own fix, which I’d like to share with you.
Please let me know your thoughts on this and if there are any mistakes I should be aware of.
Edit the macros.cfg File: Locate the [gcode_macro _global_var] Macro and add the following changes:
Before:
	variable_pause_park:{'x': 0, 'y': 0, 'z': 10, 'e': 1}
	variable_cancel_park:{'x': 0, 'y': 350, 'z': 10, 'e': 1}
	variable_z_maximum_lifting_distance: 345
	variable_pause_resume_travel_speed: 150
	variable_bed_mesh_calibrate_target_temp: 65 # NOT for start_print
	variable_load_filament_extruder_temp: 250
	gcode:
After:
    gcode:
        {% set BED_TEMP_CA = params.BED_TEMP_CA|default(65)|int %} # Set Start Temperature
        SET_GCODE_VARIABLE MACRO=_global_var VARIABLE=bed_mesh_calibrate_target_temp VALUE={BED_TEMP_CA|int} # Update Global Variable
        {action_respond_info("Bed Mesh Calibrate Target Temp: " ~ bed_mesh_calibrate_target_temp|int)} # Tell me what is going on
Modify the [gcode_macro START_PRINT] Macro: Change the following line:
Before:
{% set extruder_target_temp = printer.extruder.target %}
After:
{% set bed_target_temp = printer['gcode_macro _global_var'].bed_mesh_calibrate_target_temp|int %}# Get Gloval Variable
Update OrcaSlicer Configuration: In the printer configuration, add the following line to the Start Gcode:
_global_var BED_TEMP_CA=[bed_temperature_initial_layer_single]
Reset the Variable After Each Print: To ensure the variable resets after each print, modify the code at the end of the section as follows:
Before:
{% elif state == 'Start' %}
    M117 Printing now!!!
    {action_respond_info("Start!")}
{% endif %}
After:
    SET_GCODE_VARIABLE MACRO=_global_var VARIABLE=bed_mesh_calibrate_target_temp VALUE=65 # reset Global Variable
{% endif %}
Hello and thx for sharing your solution.
I think (but that is not an expert advice, just my own testing), with the current probe, the temperature having lot of influence … but the real temps is not so relevant (65 works well), the important thing is to do the bed mesh after a bed soak of about 5 min minimum (or just after another print). That is boring and not user friendly but that working well for me (i am printing PETG at 75, but i let’s the initial behaviour for the bed because sometime i am printing PLA and it’s longer to wait for cold down than heat up).
I evaluated multiple option (include the bed soak on the print start, having too start print command on my slicer, implement a feature to do it on print start only after a delay after the last print (someone shared something like that for SV08)… but all include some constraints.
My conclusions are :
  • The probe have to be changed (that cost few euro, that is not a big deal… but that require time to doing that properly to avoid any damages to the printer)
  • The bed tacos fix is also an easy requirement (only require few printed parts… and time to adjust)
… and if i take time to do that, switching to klipper mainline is also a good deal (and on the repository, lot of optimized gcode are suggested)… so i did nothing yet xD
Those are valid points, but my main concern is that it takes a long time for the bed to cool downafter the leveling process, when printing at lower bed temperatures. It feels like I can save quite a bit time when heating the bed to the printing temperature right away.
Thanks for sharing this.
I was about to try something similar and you saved me some time.
nice work
I tried out your changes. They worked for shortening the time required to get ready to print. Thank you.
Thank you, it works for me great!
