Mains switch stuck on, second time
Mains switch stuck on, second time.
It happened, then I purchased a new one and replaced it.
A few months it happened to the new replaced switch. Suck on again.
May have fixed it..
Unplug then spray some 99% Isopropyl alcohol, swich the switch. Leave all night to dry out. Plug back in.. it worked… don’t know how long for
@sovol3d
Without a LOT more investigation this is only speculation but you may have a flakey power supply that is causing excessive arching when turning off or on.
Ask Sovol why 2 switches could fail in such a short time.
