My sv07 Plus won’t power on. I changed AC outlets and swapped power cord with same result. Are there any fuses that are replaceable?
Thanks!! I will take a look.
My switch went bad on mine. You can buy the complete IEC320 C14 switch/fuse plug assembly online for about $5.
Thanks for the info, Larry. Sovol shipped a new switch but in the mean time, I switched the the other set of poles on the switch to continue printing.
how do you know if it is the switch?
For my SV06, it stopped clicking when I switched it on/off…there was no resistance.
Twice it even lit up, that part of the switch isn’t wired.
Oh ok, so did u wire your new one in?
Yes, I posted a link in your thread.
now it works, ok i guess ill try that. did u orderf rom sovol ?
Sovol don’t sell switches.
saw this thanks, just ordered on amazon. should have it on saturday. hope it works.
hey all that responded to my question, thank you so much. it worked. i installed it and there was a light . thanks so much.
