Long and tall prints failing repeatedly
I have a new issue. I have successfully printed the same types of models that are tall and very long prints (over 24 hours) several times in the past. Recently I have tried to print a similar model three or four times now and it looks fantastic for almost 24 hours straight and then it will turn into a spaghetti mess and I have no idea why. I am using a microswiss hotend with the regular nozzle not the CHT one. I have PID tuned. But I did notice something that makes me wonder if it is the cause.
Because the prints keep failing when the gantry is at a very high z height, I noticed that when I home the printer after the failure from that Z height that the cable drags across the linear rail and bumps and brushes against the belts on that rail and the gantry rail next to it on the X axis. Could it be rubbing the belts and causing missed steps or something at this z height resulting in the spaghetti mess? All other shorter prints work fine.
It sounds like you don’t have the enclosure right ?
The cable chain that is also used for the enclosure might help in this case, I also tie-wrapped a stainless steel (springsteel) to the toolhead cable making it arch high instead of dragging it around.
I don’t have an enclosure
like this
Thanks. I might try to replicate this! I guess I can explore adding the chain even without the enclosure. What is the purpose of the chain @wrusman ?
I think that is mainly for the cable between the base and the flying gantry not to get pinched between the gantry and the enclosure or pinched between the gantry and the base.
Without the enclosure it can bend outwards.
Did you manage to solve the confusion when printing high? Two days ago I printed a box with a height of 305mm, after 20 hours I threw away a layer and a kilogram of plastic in the trash. Now it prints again, so after reading your post I'm worried.
@matopelikan57 so yes I was able to print the same troubled model after 3 failed attempts and 3 wasted kgs of filament. I made four changes, one was I removed the spool holder and changed to feeding from my filament dryer with a printed bracket from printables that put the filament run out sensor at a 45 degree angle, I switched the ptfe tube to a better one, I upgraded to the sovol Eddy sensor, I added a printed bracket to the back part of the gantry to support the cable on an upright position.
Which of these solved the issue I am not sure, but I feel like the position of the filament run out sensor and the cable bracket on the gantry were probably the changes directly related. I think the cable was hitting the belts at that height and causing a layer shift..
Thank you very much
which printed carrier did you put on. there are more of them on printables. I tried with a chain up to the tool head and it didn't work. I used ASA and after a few hours the chain links at the joints were scraping and the gap was increasing, my chain was hanging more and more. after 20 hours of printing it was getting in the way
I don’t have an enclosure. I would have to search for the model again but this is what it looks like.
I feel sorry for wasted money for sv08. and after a month and throwing away 5 kg of filament, I was not able to get a competent print that is ok. this print is 990 g. every time it exceeds a height of approx. 250 mm, crap happens. as you can see on the x axis, it expands my wall by approx. 1-1.5mm. on both sides of the building. Y axis is ok
