Why does the Sovol Eddy Manual say to connect the Motherboard Fan (fan on aluminium cover) to Fan2? I thought Fan1 was for the motherboard fan. Which is correct Fan1 or Fan2?
Is there a typographical error in the eddy sensor instructions?
In printer.cfg this socket is mapped to
[fan_generic fan3] # exhaust fan
pin: PA2
max_power: 1.0
However in the Pin Out diagram the socket with PA1 is clearly labeled Motherboard Fan 1
Pin PA1 does not appear in printer.cfg.
Was the fan intentionally moved to allow the motherboard fan speed to be adjusted with klipper controls? If so what happens to users with both an eddy and an enclosure?
