Error Message "The value 'fan2' is not valid for FAN"
Printer was working great, had about 100 hours on it. Upgraded to the Sovol Eddy Sensor kit following all the instructions and even watching a few videos first.
After rebooting and trying to start a print (any print) I get the following error and then the job cancels “The value ‘fan2’ is not valid for FAN”
I’ve done searches throughout the config but cannot see any reference to a fan2. Where should I be looking to correct this issue as I haven’t found anyone with the same problem and a solution.
The actual configuration used at print time has any [include] spliced in. In your case I think you need to look in macro.cfg to find the “fan2” reference.
The simplest way to debug is to download klippy.log from your printer and run it through
https://sineos.github.io/Klipper-Advanced-Log-Inspector/#configs
Having the entire configuration in one chunk simplifies finding errors. The downside is you’ll still have to open xxx.cfg to edit.
Thanks. I didn’t see any reference to FAN2 in macro.cfg however I found fan1 and fan3 in printer.cfg. I tried a few edits and what finally worked was changing “fan3” to “fan2” and then I no longer received the error and was able to resume printing.
I still don’t know where the reference to fan2 is coming from.
Appreciate the assist.
Assuming you are using Orca Slicer, try this:
Edit Printer settings
On the Basic Information tab, scroll down to Accessory and make sure “Auxiliary part cooling fan” is not checked.
I hope that helps.
I think it is an error in the update manual. The motherboard fan is fan1. I have just added the sovol eddy and used fan1 for the motherboard fan. Working fine.
