Hi. For the Fan port in the upper left, it is not controlled by MCU, it is just a 24V power supply port. This port has no mapping pins. It has a 24V output by default when powered on. It is a normally open fan port and cannot be controlled.
Thank you. The orange highlight you have made is the label for a port more central to the board (the blue line goes down and to the right). I dont believe it’s intended to label the port circled in orange (which has a label of FAN2 next to the header.)
Ahh thank you, sounds similar to what I had to do with my Sibor Voron 0.2 (added a zerow to host a camera and control a relay).
Never used Katapult or the Nano, browsed the Github, but do you have a recommended guide for a process close to what I’m trying? Either way looks like I’ll be doing some reading. Thanks!
I think I’d like to use CAN to keep everything underneath the printer, plus, something new to learn. I see there is a 4-pin CAN1 and CAN2 port unused on the main board. I have an EBB42 CAN V1.2 board laying around with 2 fan ports on it, I assume if I figure out how to flash everything appropriately I could use that to switch the fan?
It appears, however, that there are no pins not in use. The switches and LEDs are soldered leaving the 4 motor pins as the only plug. I assume the USB is for programming the MCU.
Good morning, some information regarding the fan ports on the SV08 Max motherboard. I’ve just discovered that the FAN2 port isn’t controllable, but the motherboard cooling fan port, which corresponds to FAN3 on my motherboard, also can’t be controlled via Klipper and is therefore always on.
So which ports can control a 2-pin or 4-pin fan, only the K-FANs?
how to? can you help me to modify the file configuration? i want to control the fan3 (motherboard fan), which file have to be modified?
then fan1 is uncontrollable? i suppose…
