Enclosure fan
The fan for the SV08 enclosure is apparently a 24v 8025. Does anyone know where it plugs in? What type of connector? 2-pin? How is it controlled?
From the enclosure instructions it shows the fan plugging into the connector above the 4X10 main board fan BUT I’ve seen that fan being moved to that connector to turn it on/off to keep the noise down: FAN 3 = PA2 which is setup for the exhaust fan
Thank you. Sovol told me to connect to fan2. I’ve connected to it with the printer cold, and the fan does not power on. So, I am thinking it must turn on when the printer is hot. I’m not sure. I will be testing it in a while when I get my enclosure finished.
You should be able to use Klipper to set any fan regardless of the temperature.
Thanks. Delving into Klipper is above my head I’m afraid.
If your talking about the Enclosure Exhaust fan
START GODE
M106 P3 ; Turn ON Exhaust Fan 100%; PLA allow doors to be closed but open top or for ABS totally closed. Use example PWM M106 P3 S128 = 50%
and off in the END GCODE
M106 P3 S0; Turn OFF Exhaust Fan 100%; PLA allow doors to be closed but open top or for ABS totally closed. Use example PWM M106 P3 S128 = 50%
I use it like this :-
SOVOL SV08 PLA open the doors, no need. I keep mine closed… for PLA
2 pin using PWM, so far as I know, you can set the speed
More:-
