Fillament load dosent work
You most likely have a piece of filament stuck in just below the feed gears.
Take off the outer cover, unplug the lights and set aside. Remove the tension screw (note the order of washer, spring, bolt) and swing the lever all the way down and look. It may be necessary to remove the heater/heatbreak and use the “push tool” from the bottom.
