I’ve just unboxed my printer and followed all the directions to set it up. That went well. I’ve downloaded Orca and seem to be ready to print. All I have left to do is load filament and I can try sending it a print job…
I can’t figure out how to load the filament. Followed the directions in the book, but filament never loads.
I feed filament up through the bottom opening, and the light turns green. I then push the little lever and give the filament another little shove; it moves up a little, but not much. I then push the button on the front of the feeder and it makes a whirring noise, but filament never advances.
I’m using the little sample roll of filament that came with the printer; that’ll be Sovol PLA in white.
Any guidance on how I can get the filament to feed?
Filament loading is often eased by careful shaping of the filament. If there any kinks within the last couple inches trim it off. If the end is curved, common for small tightly coiled sample spools, gently reverse bend the last few inches until it is somewhat straight. Then cut the tip on angle and then cut half of the angled portion from the opposite side to have a point near the center like the tip of a sharpened pencil. Then with the ptfe tube disconnected from the extruder and a few inches of filament extending out of the ptfe tube try hand feeding the filament gently into the extruder while detensioning the internal feed rollers with the lever. After feeling the filament slip through the rollers release the lever. If the filament does not pull out with a gentle tug it should be successfully loaded and you can proceed with automated loading or separately heating the nozzle and advancing the extruder until you see smooth extrusion. Then seat the ptfe tube and you are good to go. With practice you will probably be able to load filament without disconnecting the ptfe tube but it helps at first to get a feel for what is going on in the extruder.
I should have said start by disconnecting the ptfe tube and pushing a few inches of filament out. Then do the shaping and manual insertion as stated before.
Also to disconnect the ptfe tube you need to pull out the locking clip so you can press down the barrel of the connector while gently tugging the tube out. After reinserting the tube you may find the connector holds fine without using the locking clip and I don’t bother with them on most of my printers.
I had a moment before we went out to take the feeder apart and look at what was happening. I should have taken a photo, but it was very small and lots of black plastic parts so I’m not sure it would have made sense.
The filament was feeding in the lower hose, and then not going straight past the grabber wheel into the upper hose. It was turning a hard right and hitting the edge of the feeder.
I fixed this by uncoiling a loop or two of filament and straightening it better so it would go across that gap to the upper tube, and then the motor picked it up and it made it to the extruder.
So, pretty much what you all suggested.
Thanks very much, and off I go to try and Print Something!
