Had to buy a new sensor and after I’ve installed the new one I can’t get the printer to work right. Whenever I try to calibrate it, it has to do an auto home first and it always crashes into the bed so I have to power it off.
The sensors red light is on, it is mounted correctly and at the correct height. I flashed the firmware and I reset the eeprom several times.
I’ve had the problem before and fixed it but that was a while ago and I can’t recall exactly what I did.
I don’t have another printer but thanks. I am going to print the holder for another probe I have. It is really difficult to get the probe out of the holder btw. I ended up just cutting away the holder from the probe even though it just screws into the holder.
