2 Problems with my printer
My Y Axis is out of alignment. It tries to print off the back of the print. The purge line prints to the Heated Bed connection.
Another problem I have is when I try the Z Tilt it fails saying the increments are increasing.
Thank you for any help.
The axis is aligned every time it is “homed”. The sensorless homing process moves the plate until the motor stalls. Something is blocking your bed from moving freely to the rear.
Try adjusting the roller on the bottom of the toolhead. Mine was loose allowing the toolhead to tip slightly. Turning the eccentric post to eliminate the shake fixed my machine.
