Power on, & the display turns an orange/red hue, & nothing else happens. Doesn’t boot, no logo displayed etc.
I’ve contacted the seller to let them know it’s faulty, but if it’s something easily remedied, I’d rather just sort it than go through a return & replace scenario.
Just hooked up a display, & I’ve configured wifi via that display. It’s connecting to the network. This is the error message displayed, on that screen.
Not as yet. I have dug out a spare EMMC card/module & writer I had knocking about though, so hopefully I’ll get chance to try that tomorrow. Downloading the image from Drive as we speak.
The screen is probably okay, it is connected TO the main MCU. Without instructions from the MCU nothing gets displayed. The MCU does nothing without instructions from klipper. The HDMI connects to Linux at boot as a system device. KlipperScreen launches after boot runs in parallel with klippy.
Your error message calls out [mcu] not [extra_mcu] in the toolhead. NOTE: Your HOST (H616) and the main MCU are both on the same circuit board but Klipper handles them as separate devices.
Most likely the mainboard didn’t enjoy the container ship ride and a so-so solder joint (or similar) broke in transit. BUT if you can find a valid CAN address it is possible that re-flashing the MCU could revive it.
Thanks cardoc. I’ve finally had chance to have another look at this. I flashed another emmc card & fitted it, just to completely rule that aspect out, but as you advised, it’s made no difference. Same error message appearing.
How would I go about trying to find a valid CAN address?
Looked at the Mainsail interface, & that devices option wasn’t there. With it erroring, it appears to be only loading part of that.
Hopefully, I may have a replacement motherboard due to be sent. The seller has suggested they’ll send a replacement motherboard & EMMC module. So, fingers crossed.
