found how to get nozzle to bed marlin m851
M851 - XYZ Probe Offset
none Set the Z probe XYZ offset from nozzle HAS_BED_PROBE
Set the XYZ distance from the nozzle to the probe trigger-point.
The easiest way to get the Z offset value is to:
- Home the Z axis.
- Raise Z and deploy the probe.
- Move Z down slowly until the probe triggers.
- Take the current Z value and negate it. (
5.2=>-5.2) - Set with
M851 Z-5.2and#define Z_PROBE_OFFSET_FROM_EXTRUDER -5.2.
For X and Y you have to measure the distance.
Notes
The default (factory) values are set by
- (version 1.x)
X_PROBE_OFFSET_FROM_EXTRUDERY_PROBE_OFFSET_FROM_EXTRUDERZ_PROBE_OFFSET_FROM_EXTRUDER
- (version 2.x)
NOZZLE_TO_PROBE_OFFSET
and are integer values.
Positions: X offset: -left +right [of the nozzle] Y offset: -front +behind [the nozzle] Z offset: -below +above [the nozzle]
+-- BACK ---+
L | (+) P | R <-- probe (20,20)
E | | I
F | (-) N (+) | G <-- nozzle (10,10)
T | | H
| (-) | T
O-- FRONT --+
(0,0)
Usage
M851 [X<linear>] [Y<linear>] [Z<linear>]
also found m206 to be useful
M206 - Set Home Offsets
motion Apply a persistent offset HAS_HOME_OFFSET
Use M206 to apply a persistent offset to the native home position and coordinate space. This effectively shifts the coordinate space in the negative direction. See examples below.
- The current position is adjusted to align to the new home offset values.
- The home offset is persistent — added to the current position until changed.
- Some uses include fine adjustment of Z position (without moving endstops) and shifting the coordinate space to print on a different part of the bed.
Notes
- This command isn’t available on
DELTA. (For delta useM665 H.) - This G-code can be disabled with
NO_WORKSPACE_OFFSETSto optimize movement. - Changing the home offsets will not invalidate bed leveling or other saved data.
- View the current offsets with
M503. - If
EEPROM_SETTINGSis enabled, the home offsets are saved withM500, loaded withM501, and reset withM502. M428sets home offsets so the current position aligns to the native home position.
Usage
M206 [P<offset>] [T<offset>] [X<offset>] [Y<offset>] [Z<offset>]
Parameters
[P<offset>] |
SCARA Psi offset (Requires MORGAN_SCARA) |
[T<offset>] |
SCARA Theta offset (Requires MORGAN_SCARA) |
[X<offset>] |
X home offset |
[Y<offset>] |
Y home offset |
[Z<offset>] |
Z home offset |
