Z Offset
Am I the only one having Z Offset problems, I have attempted completing the Z Offset multiple times with no success. When printing the first layer, I have to adjust the offset on the fly to get a good first layer. I must be doing something incorrect to not having a problem everytime I attempt a print.
The Max uses the same Nozzle tap + eddy process as the Zero. Lots of discussion on that thread.
Boils down to, if your nozzle isn’t 100% clean then Z offset will be high.
See the Zero thread for custom nozzle cleaning macros (will have to be reworked for the bigger bed and different brush location)
Thanks, I will go there and see what I can do.
You might also try adding a thicker first layer.
