10 days ago I received the sv08. I have a problem and I need help. I have a problem with the z-offset. I let the leveling go and the test print is not good at all. While printing I adjust the z-offset and at the end it saves, it does an auto restart. The next time it is too low for me by two tenths of a millimeter, sometimes even more. It scrapes the substrate. I adjust it to be ok and save and the next time it asks me 02 is too high. The bed frame is ok. I heat the bed to 65c. help please
EDIT: Please stop using the 3 dot code in your posts…Lion
Did you heat your bed and hotend before execute the leveling ?
10 min I hoped it was enough.
It’s not a question of time.
Heat your bed at 60° and the hotend at 120°.
installed eddy, problem solved. thanks
ned, 19. lis 2025. u 22:17 mich0111 via Sovol3d forum <notifications@sovolforum.discoursemail.com> napisao je:
And how did you solve your problem?
My question is to help other forum’s users.
It seems that my Proximity Sensor was not working properly, one print had a z-offset that was too low so the nozzle scraped the bed, I raised the z and took a picture, but at the beginning of the next print it was too high. Now with eddy it’s the same every time. and to warm the bed every time but not for too long 5-8 minutes
EDIT: Lion
