I’ve mostly gotten my new printer working and have made some prints. Some good some not so good. I’ve learned that the Z offset is super important which is fine, except mine seems be change a lot. What it the best way to set the Z offset and hopefully make it mostly stay put?
Hello RandyB
Hello, z-axis compensation value is a very small value, if there is a slight change is very normal; and printing process, you can adjust the z-axis compensation value at any time to achieve a good printing effect
- You can check whether your bltouch probe is normal, has it been bent? If so, please replace the spare probe.
- Is there any shaking of the hot bed plate? If so, please tighten the eccentric nut of the pulley underneath.
- If there is no problem with the above, it may be a firmware problem, please try to refresh the main version firmware.
Thank you
Best regards
Sovol Team
As an update, I updated to the latest version of Sovol Cura and all my problems went away.
Nice! It is a good news!
