Hi All,
I just purchased a SV03 and new to 3d printers. I am trying to level the bed and have a few questions.
When I level each corner, the knobs on one side under the bed unwind all the way ( I think this is due to the x axis not being level , looks slighlty out and Idon’t know where to start with that issue) I can manage to just make the .2mm gap but I don’t think this is correct with these knobs so far out.
After that issue, I try to adjust the Z offset but whatever direction I move the knob the nozzle does not move. I did however do a auto home and it pushed the nozzle into the bed.
I don’t know what I am doing wrong, The instruction booklet says 1 thing, and the official Sovol SV03 bed level video does it a different way.
Hopefully someone can give me a few quick pointers as I am keen to get this printer up and running.
Thankyou for any help.
So after a lot of messing around I finally got this printer to work.
Z offset is not as advertised, it will not move if you follow instructions from Sovol.
Here is the fix for the Z offset.
I still don’t know why the bed knobs need to be screwed out so far, but I got success with the above solution. Hope this helps someone, and please remember to do these steps at your own risk
I had a similar issue with the Z offset not budging, but I found that using a different slicer like OrcaSlicer helped me troubleshoot and get more consistent results. You might want to give it a try—it could help in fine-tuning your settings!
