When itry to boot up my SV07 it boots up most of the way and then starts at the begining again and gets cought in a loop
That’s how I did it except mine came with a 32Gb chip and came from Ali for $14
I’ve never done it but I’m told You CAN flash on the board once you figure out the secret to get it to boot from USB.
Easiest way is with a USB keyboard. You have to use Etcher on your PC to expand the OS onto a USB drive. Then you need a copy of the .img on the same or 2nd USB drive. Boot from the USB then copy the .img onto the EMMC
What files should I put on the EMMC when I get the USB adapter?
Go to the link in my first post. There are 3 options
  1. Bone stock Sovol (plus the optional update if you choose)
  2. Prebuilt image based on a more recent version of Armbian
  3. Current version of Armbian then manually install Klipper and the Sovol extensions
I chose option 3 but 1 is the easiest.
Whichever route follow the instructions linked above.
i got it to work again thank you all for your help the USB adapter worked amazing!
again thanks all of you
