I had a good “out of box” experience with my SV07 and Klipper. Unfortunately the latest update resulted in Mainsail replacing Fluidd as the default interface.
I MUCH prefer Fluid so I set to learn how to install Fluidd on the Sovol Klipper Pad. What a rabbit hole that was with horror stories about failed updates and configuration issues galore. I very nearly gave up until I stumbled acros https://github.com/Joyce-lujunxu/SOVOL_KLIPAD50_SYSTEM
Halfway through the Readme it says " IP address of KLIPAD50 with your PC’s browser, and you can either enter mainsail interface with the default port of 80, or fluidd with the port of 81"
Why did it take 5 hours to find that??
TLDR : Append :81 to the end if your IP address
