My trusty SV06 that I converted to Klipper about a year ago has decided to stop working. The screen boots fine, machine homes fine, bed and extruder heat up fine but I cannot connect it to wifi or use Mailsail any more.
I have rebooted it numerous times with no change. I cannot figure out how to reflash the firmware.
Any suggestions on what else I can try?
You can access through ssh to your klipper and take a look to the file /etc/network/interfaces to check if the datas are correct.
It’s a step.
Good luck
Thanks, for some unknown reason today when I powered it up it decided to connect to wifi and Mainsail could reach it. No idea why it suddenly decided to start working again.
