Updating Klipper, Mainsail, Moonraker and system
After finally getting WiFi working, I wanted to check to make sure Klipper, Mainsail and Moonraker were updated, they weren’t, along with 46 system packages. I enabled update manager by uncommenting it in the moonraker.conf but when I try to update it fails. The first issue was git saw the code as dirty, doing a HARD update fixed that but when I tried to update it fails because some file isn’t right or something.
I’ve emailed Sovol about this, I hope I don’t have to rely on Sovol to get updates
Update: I found Sovol says to use kiauh to update, I tried it, it has the same error:
| ~~~~~~~~~~~~~~~~~ [ KIAUH ] ~~~~~~~~~~~~~~~~~ |
| Klipper Installation And Update Helper |
| The following installations will be updated: |
| ● Klipper |
| ● Moonraker |
| ● Mainsail |
| ● KlipperScreen |
Do you want to proceed? (Y/n): Y
Stop klipper-mcu.service …
[✓ OK] Stop klipper-mcu.service successfull!
Stop klipper.service …
[✓ OK] Stop klipper.service successfull!
Updating Klipper …
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace “git config” with “git config --global” to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
Updating 02eeceb..6c1004f
error: The following untracked working tree files would be overwritten by merge:
klippy/chelper/c_helper.so
Please move or remove them before you merge.
Aborting
sovol@SPI-XI:~/kiauh$
Installed the new firmware 2.3.3.6-20 moonraker updates but klipper has the same error and fails:
Updating 02eeceb…6c1004f
error: Your local changes to the following files would be overwritten by merge:
klippy/chelper/init.py
klippy/extras/display/display.cfg
klippy/extras/display/menu.cfg
klippy/extras/display/menu.py
klippy/extras/resonance_tester.py
klippy/extras/virtual_sdcard.py
out/autoconf.h
out/board
out/src/basecmd.d
out/src/command.d
out/src/debugcmds.d
out/src/sched.d
Please commit your changes or stash them before you merge.
Aborting
After a day of trying to restore the machine to factory I removed the emmc card and used the latest image with Raspberry PI imager.
Don’t enable UPDATE MANAGER
Don’t ssh into the printer and run kiauh.sh to update klipper or other apps
Sovol, please remove Factory resets, it does nothing and try using a little less glue on the connectors, on dab would hold the connector in place, covering the entire connector in glue risks destroying they connector while trying to remove the mess, your ‘glue’ acted like / looked like hot glue…
Ask Sovol when it will be possible to update klipper and support apps.
Well, all of that is repairable in priciple. I managed to clean my install up quite well and got all those updates to run - and some of the people on the discord are currently working (with quite some success) on a way to get mainline Klipper on the machine: GitHub - Rappetor/Sovol-SV08-Mainline: Getting the Sovol SV08 onto mainline Klipper
I also created an issue on github asking Sovol to have a look at a mainline install, but our research as shown quite clearly that absolutely nobody at Sovol has a clue about git, let alone about github. I don’t expect that anybody even reads those issues, sadly. Evaluate if baseline Klipper can be used instead of a modified version · Issue #11 · Sovol3d/SV08 · GitHub
What discord server? The git link was amazing, he has spent weeks tweaking, at that point it appears you might as well replace the controller with a BTT M8P+CM4
Just minor suggestion - when you want to remove the connector, use isopropyl alcohol on the glue and wait 5-10 seconds. It will harden the glue and you can literally break it away from the connector without any strain or damage. Works like a charm. I agree they went a bit above and beyond, plus I would expect more silicone than hot glue, but at least it’s easy to remove :slight_smile:
thanks for the info.
Is there any easy way to update Klipper / Mainsail / Moonraker / … on default Sovol SV08 firmware without bricking the device or going all-in by installing mainline Klipper (with many hours of work).
Would be nice to see a working tutorial for updating the existing Sovol Klipper install.
Sovol SVO8 Not true full killer
I also hope that someone can finely crack the Sovol Clipper lock out. I am thinking that just might solve alot of problems with the printer. It would also allow us to install thoes Deamon mackrows?:grinning:
ssh into mine and tried to run updates etc.
Now resonance shaping fails with the error
“Failed to import numpy module, make sure it was installed via ~/klippy-env/bin/pip install (refer to docs/Measuring_Resonances.md for more details).”
is there an easier fix than just converting completely to mainline clipper?
Suspect i need to do this am a bit of a noob is there a "how to " for doing this somewhere i think i get the idea of it
would it be better to just go the effort of converting completely to mainline instead?
Any updates on Updating Klipper, Mainsail, Moonraker on SV08?
I havent done much research as to posting this, but it seems like git is a integral part of the update process. And weirdly enough, it seems like there are alot of uncommited changes to the git repositories in the modules for moonraker and other applications.
It almost seems like Sovol has cloned the repoes, made changes without forking, or creating a branch or anything…
So I could imagine it would be a possibility to check out to a new branch, commiting the changes there, checkout the parent branch without sovol changes and run the updates? If you want to bring back the configurations etc sovol has made, you could check out a new branch from the updated one, and pull inn the changes from the sovol branch.
Done with rebase this should result in updated software and with the changes made by sovol back again. You would have to watch for breaking changes tho, so it wont be a straight forward path.
Well I just used kiauh and updated everything….hope it doesn’t mess anything up. I was able to get into my Wi-Fi network afterwards, but Moonraker is still not working.
Have you tried to SSH and run KIAUH?
How did you get on after your updates? I taught that Sovol recommended NOT TO UPDATE THE SLICER?
