SOVOL SV08 told me it is not possible, at this time, (a firmware for their display update maybe, sometime, if at all in the future), to change or set the time on their 5 inch display; Hope they do!
It seems to me that SOVOL SV08 Klipper is not the full and complete version of Klipper, e.g. a few, about 2, other users config files do not appear to function for me.
Maybe a Bigtree Tech display is better.
Thankyou very, very much for trying to fix it for me
I think it is a Time Zone issue. My Sovol 5 inch touch display is out by I think a time zone issues : Sovol have told me no fix.
Mine e.g. shows 8:23 pm when it is 9:30 pm
When I noticed time displayed in UTC on the HDMI touchscreen connected to the SV08, I connected using ssh, and, as root, executed:
dpkg-reconfigure tzdata
and picked my location. When I did so, I wasnât aware of that there doesnât appear to exist a solution at this time. However, the time displayed is correct now.
Iâm a bit late to the party, but if you are still looking for a solution it appears your machine is not synching to a time server because Sovol failed to add the necessary client so it canât connect to an NTP server to get the correct time.
SSH (via Putty or other terminal) and enter:
sudo apt install systemd-timesyncd
Next enter
timedatectl set-ntp true
You will probably be prompted to enter the password again, but once thatâs done the printer will sync the internal clock to the network time. Then you just need to set your time zone, as described earlier in this thread.
