SV08 Max – Original Mainboard Firmware Recovery
Hello everyone,
I’m trying to restore my Sovol SV08 Max to its original factory firmware after previously flashing modified firmware onto the STM32H750 mainboard using an ST-Link V2.
The printer is currently stuck on the Sovol startup logo. I have installed the official 2.0.9 system image, and my ST-Link successfully connects to the mainboard MCU.
Does anyone have the original Sovol STM32H750 mainboard bootloader and firmware HEX files, along with the correct ST-Link flashing procedure?
I’m looking for official factory firmware only, not custom Klipper builds.
Any help would be greatly appreciated. Thank you!
What happened to the backups you saved before rewriting the MCU?:wink:
@ATC3D Do you have the files Sovol sent you?
@sovol3d Can you provide the needed files?
It might be possible to find the bin in the git for the svo8 klipper files but it might be better to look at an older iso back up of the printer and pull it from there
Firmware on the Wiki:
There are no STM32H750 mainboard firmware, bootloader, or recovery HEX files in this folder. Not sure why no reply @sovol3d from an email sent a while back.
I do have the files if still needed
Provided by the original hardware of the unique machine.
Disk ima
chamber_hot.hex (84.3 KB)
SV08MAX Auxiliary Feeder PCB Board.hex (85.3 KB)
SV08MAX Mainboard.hex (94.8 KB)
Nozzle Board.hex (84.3 KB)
ge file: https://drive.google.com/file/d/1A7mfdH0gTU4VS60ker5Rnl1muqiNfMMP/view
Hi everyone, I need help with my Sovol SV08 Max. The printer powers on but stays stuck on the Sovol logo.
I’ve already installed/flashed the following:
  • H616 Linux firmware: H616_2.3.3_debian_sovol-sv08max-2.0.9.img
  • Mainboard: SV08MAXMainboard.hex
  • Auxiliary feeder: SV08MAXAuxiliaryFeederPCBBoard.hex
  • Nozzle board firmware
  • Tested both the original 8GB eMMC and a replacement 32GB eMMC.
All STM32 firmware flashing completed successfully using ST-Link and STM32CubeProgrammer. I also attempted UART troubleshooting but couldn’t obtain readable boot messages.
The printer still won’t boot past the Sovol logo.
Has anyone experienced this problem or knows what else I should check? Any help would be appreciated.
The best thing to do is to send an email to info@sovol3d.com, including your order number and explaining your problem.
They will respond within a week.
Have you tried to connect via Fluidd/Mainsail? Chances are klipper is running but in an error state. The knob screen will not update until the mainboard MCU initializes. If Klipper can’t communicate with the MCU there will be an error message shown in the console.
Please email us . info@sovol3d.com
i did. A couple of hours ago
i tried, machine does not connect to the internet to be able to see it. Tried HDMI as well to see if there are any error on bootup but only a black screen on the HDMI. Installed the software’s from sovol and the ones you provided and nothing past the main Sovol logo. I have a blue light at the toolhead, i checked all the wires and everything seems to be in place. Pretty worn out at this point.
What do you get on the HDMI if you power up with the EMMC removed? Should be a plain text output similar to “No bootable media found”. That proves the CPU half of the board finishes the “Power On Self Test” (POST) and is starting the boot process. It then crashes due to EMMC hardware or software faults. No output would make me think the mainboard is toast.
There is a generic Armbian build at:
https://armbian.com/boards/sovol-sv08-max
It might be worthwhile to flash it to your EMMC and see if it generates any output to your HDMI screen.
I don’t have a H616 board here but the Klipad50 on my SV07 will boot from USB only if the EMMC is missing or blank. You could use etcher to put ambiain on a usb device. YMMV.
Yes, i tried with with and without and the results remained the same both times, a blank screen, no display on the PC
If you have access to Claude, it can walk you thorugh. I saw someone here posted the files. I mainlined, un-mainlined, and re-mainlined with claude.I ditched their crappy compute unit and using my own pia via CAN all with claude, and that’s something that there is, or at least was, any guide for it. The free one might not be enough, but the 20/month one is definitely enough.
Normally, I would advise having at least a clue of what you are doing even when working with the AI, but at this stage, yours is already broken :stuck_out_tongue:
Blank HDMI with the eMMC removed isn’t conclusive that the mainboard is dead—many H616 boards won’t output video until they find a bootloader on eMMC/SD, so no “No bootable media” message can still be normal. I’d keep the two sides separate: the 2.0.9 image is the Linux/H616 host, while the STM32H750 needs its own bootloader/firmware via ST-Link. Before chasing files, read back the H750 flash in STM32CubeProgrammer and confirm BOOT0/option bytes and the flash base address; that will tell you whether the MCU is actually programmed. Sovol is still the only reliable source for the official HEX.
I managed to get it going. I had to get the old h616 file and upload it. Once i uploaded it took a minute to atart but it started.
