I finished leveling my bed, and an error popped up for Bed Temp, and to reset. I checked under the bed and this wire was disconnected. What can I do?
Bjoern
January 24, 2023, 6:16pm
2
Honestly? The fast way is to strip a bit of the insulation & solder it or ask someone who is capable of doing that for you.
The other way: Make a warranty claim, send your printer abroad & wait until it comes back…
They will send a new bed out and you can replace it quite easily, no need to send the printer back.
I had a similar problem but mine was the positive lead coming off.
As the bed bled the heat from my soldering iron I couldnt get the pad hot enough to solder it back on.
Contact support by email and they will send a new bed out. To speed things up take a photo of your serial number on the bottom of your power supply as they will ask for that. Yeh I have been there…
The reason mine failed was that the main part of the lead wasnt zip tied and the back and forth motion caused the cable to get br…
