So I have an SV06 and am running it with a sonic, pad problem is it does not have enough flow to really print all that much faster than it’s standard settings, does anybody have both printers that could confirm if the plus heat block would attach? It is easy to adjust the bed level sensor to accommodate and easy to make an adjustable fan duct to compensate for the length.
If not that will the entire plus extruder and hotend just drop in because it sure looks like it would.
