Good day all!!!
Has anyone installed a HERO ME? I am looking for the details to put one on a SV06 Plus…
Such as the Extruder - Bed leveler…
Good day all!!!
Hi, i was interested but it seems some parts are not yet supported, nozzle, heartbreak…
If not tell me ![]()
So Specific to the SV06 or SV06 Plus
Extruder Direct Drive Mount - SV06-Plus
Gantry Adapter - SOVOL
Havent found anything specific for ABL Mount - need to do more research to see if any other machines run the same as Sovol
ADXL Shouldn’t be a problem.
Universal Base STL and the Universal Skirt STL should work
Hotend Adapter - nothing specific however someone mentioned it was similar or the same as the Micro Swiss MK8 - if that is the case then the HMG7 Micro Swiss DD MK8 Top Cap might work… but that is a guess…
no idea which set of Part Cooling Ducts to select. If the SV06 Plus is indeed like the Micro Swiss DD then that might work…
Planning on 5015 fans have several of those on hand.
Thanks!
