Sign below to ask Sovol to adjust the SV06 heat block design to use a standard Volcano nozzle so that users will have enough options. This is the one decision that will kill an otherwise excellent offering!
Thank you for your feedback. We understand your concern regarding the SV06 heat block design and its compatibility with standard Volcano nozzles. Our team is currently looking into ways to address this issue and provide more options for our users.
I’m not really sure what you need to do to “address the issue” other than use a standard volcano style hotend. Your nozzles use the same thread pitch, right? But the actual nozzle is a few millimeters longer, and that’s all?
Thank you for your question. Yes, you’re right that using a standard Volcano hotend is one possible solution to this problem. However, our team is also considering other options, such as improving the cooling fan’s guide vanes, which is currently under development. We appreciate your patience as we work to find the best solution to meet our users’ needs. ![]()
Bonjour
Je suis tout a fait d’accord il faut trouver une autre solution pour la buse !
Bonne soirée
Cordialement
My guess is it’s really just greed. Using a proprietary nozzle means no one else will make them and you’re forced to buy from them.
Hm, I still waiting for my SV06 Plus to arrive. But whats the problem you encounter? I already used M6x16 nozzles without much changes in my SV06. Why should they not fit in the SV06 Plus?
I am sorry, but I still don´t see the problem. If its a FD175M6x16 nozzle it will work. Please be more precise with your description.
HeHe
you silly problem solver,…
this must go thru many, many committee meetings
It is the Way
Yes! This.
I wish they would use standard nozzles for this printer and the sv08.
I didn’t buy an sv08 because of this. I wish it used a standard nozzle, be that mk8 (preferable) or volcano.
You can use a volcano nozzle with the SV06 Plus with minimal modification. Just have to print a new part cooler duct.
