Repair kit for SV06?
Sovol should provide a repair kit for the SV06:
Heatbreak, Heatblock, Heater, Tempsensor and the necessary small screws
It’s hard to find a suitable replacement.
If I take the repair kit from the Ende 3.
Then the Heatbreak does not fit and the connector of the Heater is different.
Need PH 2.0 but PX 2.5
And the mounting screw is too short. But that can be solved. Probably M2.5
sovol have a sv06 hotend kit that has all the parts you listed, but you might want to look at the entire sv06 extruder as a quicker and easier fix
