Sv03 not feeding filament
Okay, so I used my little unclog stick into the hot end a few times and then connected the filament back in and went into setting to control the extruder and it would work but then once I’d start a print again nothing would come out… I even grab a brand new roll that was sealed and it won’t feed… should I get some of of that filament cleaner/clog or am I missing something I usually use PETG haven’t had a issue for a while… I even picked up a dryer for filment think that would help so I’m at lost
Did you check if the gears were driving the filament?
